[GRASS-user] Eliminating values based on a null
Greetings
in my base map (called X) I have a few null values and, in Y map I want to eliminate pixels that match with null values in X. How can I do this? besides using mapcalc
Thanks
Jenny
Jenny:
Hello Jenny,
I don't know if it is a coincidence, but your problem can be solved in the
same way as Kim's problem.
You can use the module r.series with the -n flag. It will propagate the
nulls among your input rasters. The method you use does not matter because
the -n flag overrides it. So it would be like this:
r.series -n input=X,Y output=Y_without_X_nulls method=average (or any
method)
Hope this helps,
Marcello.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Eliminating-values-based-on-a-null-tp6031771p6032382.html
On 16/02/2011 18:12, Marcello Gorini wrote:
Jenny:
method)
Just curious: What exactly is the advantage of NOT using mapcalc?
Hermann
