[GRASS-user] Empty vector file and v.db.addtable
Dear GRASSusers,
I have two questions (GRASS6.2.2):
  1. Is the v.db.addtable available through the GIS Manager (I wasn’t able to find it). Or it can be used only in command line mode (GRASS prompt)?
  2. How can I produce an empty vector file? I would like to connect a couple of tables to it before start digitizing. I know it can be created by entering and exiting v.digit without digitizing anything, but I wonder if there is a more direct and specific way to do it.
Many thanks in advance
A. Clerici
Aldo Clerici wrote on 06/04/2007 12:51 PM:
Dear GRASSusers,
1) Is the v.db.addtable available through the GIS Manager (I wasn’t
prompt)?
I have added it now so that it will go into the 6.2.2 release.
2) How can I produce an empty vector file? I would like to connect a
With v.in.ascii you can do that:
-e Create a new empty map and exit. Nothing is read from input
In GRASS 6.3, also v.edit can do that:
tool=create: Create new (empty) vector map
Best,
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
