On Wed, Mar 25, 2009 at 11:29 PM, Paul Kelly
<paul-grass@stjohnspoint.co.uk> wrote:
On Wed, 25 Mar 2009, Moritz Lennert wrote:
On 25/03/09 18:05, Laura Poggio wrote:
The output of gdalinfo on the file is
Driver: GTiff/GeoTIFF Files:
data/JRC/map/DTM/ast1.tif Size is 360, 364 Coordinate
System is: PROJCS["ETRS89 / ETRS-LAEA",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.2572221010042,
AUTHORITY["EPSG","7019"]], AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0], UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4258"]], UNIT["metre",1,
AUTHORITY["EPSG","9001"]], AUTHORITY["EPSG","3035"]]
Mmmh, so coordinate system info is included and GRASS should recognize it.
The WKT is invalid though as it says it's projected, but doesn't include
either the name of the projection nor any parameters for it.
But if I used OGR's tool, I can generate it, too:
PYTHONPATH=/usr/local/lib64/python2.5/site-packages/osgeo epsg_tr.py 3035
GEOGCS["ETRS89",
SPHEROID["GRS 1980",6378137,298.257222101,
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
UNIT["metre",1,
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",52],
PARAMETER["longitude_of_center",10],
PARAMETER["false_easting",4321000],
PARAMETER["false_northing",3210000],
AUTHORITY["EPSG","3035"],
AXIS["X",EAST],
AXIS["Y",NORTH]]
grep 'ETRS89 / ETRS-LAEA' lib/proj/pcs.csv
3035,"ETRS89 / ETRS-LAEA",9001,4258,19986,9820,1,0,8802,10,9102,8801,52,9102,8807,3210000,9001,8806,4321000,9001,
