The hourly 5km LST product from Copernicus, as per the product user manual
(https://land.copernicus.eu/global/sites/cgls.vito.be/files/products/GIOGL1_PUM_LST-I1.40.pdf)
"is displayed in a regular latitude/longitude grid (plate carrée) with
the ellipsoid WGS 1984 (Terrestrial radius=6378km). This coordinate
reference system corresponds to EPSG code 32663. The resolution of the
grid is 5/112° (approximately 0.045°)."
I imported a map (netCDF) and set the region to match it. If '32633' unit is 'meter', any ideas on to do with the reported:
nsres: 0.04464286
ewres: 0.04464286
which is, obviously, not meters?
Is there something "hidden" in the netCDF file(s)?
Here is a `gdalinfo g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc`:
Driver: netCDF/Network Common Data Format
Files: g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc
Size is 512, 512
Coordinate System is `'
Metadata:
NC_GLOBAL#algorithm_version=GOES13-LST_v3.40, MSG3-LST_v7.14.0, HIMAWARI8-LST_v3.50, DataFusion_v5.2
NC_GLOBAL#archive_facility=IPMA
NC_GLOBAL#comment=Land Surface Temperature (LST) is the radiative skin temperature over land. LST plays
an important role in the physics of land surface as it is involved in the processes of energy and water ex
change with the atmosphere. LST is useful for the scientific community, namely for those dealing with mete
orological and climate models. Accurate values of LST are also of special interest in a wide range of area
s related to land surface processes, including meteorology, hydrology, agrometeorology, climatology and en
vironmental studies.
NC_GLOBAL#contacts=Principal investigator (Researcher): isabel.trigo@ipma.pt; Instituto Português do Mar
e da Atmosfera (IPMA); Rua C ao Aeroporto; Lisbon; 1749-077; Portugal (PT); IPMA website; http://www.ipma
.pt
Originator (IPMA GIO-Global Land Help Desk): sandra.coelho@ipma.pt; Instituto Português do Mar e da Atmosf
era (IPMA); Rua C ao Aeroporto; Lisbon; 1749-077; Portugal (PT); IPMA website; http://www.ipma.pt
Point of contact (GIO-Global Land Help Desk): helpdesk@vgt.vito.be; Flemish Institute for Technological Research (VITO); Boeretang 200; Mol; 2400; Belgium (BE); VITO website; http://land.copernicus.eu/global/
Owner: ENTR-COPERNICUS-ASSETS@ec.europa.eu; European Commission Directorate-General for Enterprise and Industry (EC-DGEI); Avenue d'Auderghem 45; Brussels; 1049; Belgium (BE); EC-DGEI website; http://ec.europa.eu/enterprise/
Custodian (Responsible): copernicuslandproducts@jrc.ec.europa.eu; European Commission Directorate-General Joint Research Center (JRC); Via E.Fermi, 249; Ispra; 21027; Italy (IT); JRC website; http://ies.jrc.ec.europa.eu
NC_GLOBAL#Conventions=CF-1.6
NC_GLOBAL#credit=LST products are generated by the land service of Copernicus, the Earth Observation programme of the European Commission. The LST algorithm, originally developed in the framework of the FP7/Geoland2, is generated from MTSAT/HIMAWARI and GOES data, respectively owned by JMA and NOAA, and combined with the LST product from MSG under copyright EUMETSAT, produced by LSA-SAF.
NC_GLOBAL#date_created=2016-06-22T03:22:01Z
NC_GLOBAL#gcmd_keywords=SURFACE TEMPERATURE
NC_GLOBAL#gemet_keywords=solar radiation
NC_GLOBAL#history=2016-06-22T03:22:01Z - Product generation;
NC_GLOBAL#identifier=urn:cgls:global:lst_v1_0.045degree:LST_201606220100_GLOBE_GEO_V1.2
NC_GLOBAL#inspire_theme=Orthoimagery
NC_GLOBAL#institution=IPMA
NC_GLOBAL#iso19115_topic_categories=climatologyMeteorologyAtmosphere, imageryBaseMapsEarthCover
NC_GLOBAL#long_name=Land Surface Temperature
NC_GLOBAL#name=LST
NC_GLOBAL#orbit_type=GEO
NC_GLOBAL#other_keywords=Global
NC_GLOBAL#parent_identifier=urn:cgls:global:lst_v1_0.045degree
NC_GLOBAL#platform=GOES13, MSG3, HIMAWARI8
NC_GLOBAL#processing_level=L4
NC_GLOBAL#processing_mode=Near Real Time
NC_GLOBAL#product_version=V1.2
NC_GLOBAL#purpose=This product is first designed to fit the requirements of the Global Land component of Land Service of GMES-Copernicus. It can be also useful for all applications related to the environment monitoring.
NC_GLOBAL#references=Product User Manual: http://land.copernicus.eu/global/sites/default/files/products/GIOGL1_PUM_LST_I1.10.pdf
Validation Report: http://land.copernicus.eu/global/sites/default/files/products/GIOGL1_VR_LST_I2.10.pdf
Product page: http://land.copernicus.eu/global/products/lst
NC_GLOBAL#sensor=IMAG, SEVI, AHI
NC_GLOBAL#source=Data was derived from satellite imagery.
NC_GLOBAL#time_coverage_end=2016-06-22T01:30:00Z
NC_GLOBAL#time_coverage_start=2016-06-22T00:30:00Z
NC_GLOBAL#title=Global Land Surface Temperature for 2016-06-22T01:00:00Z
Subdatasets:
SUBDATASET_1_NAME=NETCDF:"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc":ERRORBAR_LST
SUBDATASET_1_DESC=[1x3584x8064] surface_temperature standard_error (16-bit integer)
SUBDATASET_2_NAME=NETCDF:"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc":LST
SUBDATASET_2_DESC=[1x3584x8064] surface_temperature (16-bit integer)
SUBDATASET_3_NAME=NETCDF:"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc":PERCENT_PROC_PIXELS
SUBDATASET_3_DESC=[1x3584x8064] PERCENT_PROC_PIXELS (16-bit integer)
SUBDATASET_4_NAME=NETCDF:"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc":Q_FLAGS
SUBDATASET_4_DESC=[1x3584x8064] Q_FLAGS (16-bit integer)
SUBDATASET_5_NAME=NETCDF:"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc":TIME_DELTA
SUBDATASET_5_DESC=[1x3584x8064] TIME_DELTA (16-bit integer)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
Nikos
