[GRASS-user] EPSG-codes, PostGIS, GRASS
Hi to all members of the list,
I have problems with v.out.ogr writing to PostGIS.
We have set up a GRASS location with EPSG:2169 for Luxembourg. If I want to export some data to PostGIS, which itself works very well, a new EPSG code in spatial_ref_sys will be created because the parameters in GRASS doesn’t match exactly the ones in PostGIS (spatial_ref_sys). For projection everything should be fine but I want to avoid a real mess in PostGIS.
A first solution is to reset the SRID in geometry_columns for each table with UpdateGeometrySRID, but thats not a thing I want to do for every time I export a layer.
Are there any possibilities for a workaround? Maybe to set a SRID with v.out.ogr?
Thanks in advance,
Christian
Dipl. Geogr. Christian Braun
Tel: +352- 425991-608
Mobil: +49-179-6845896
Mail: christian.braun@tudor.lu
Resource Centre for Environmental Technologies,
Public Research Centre Henri Tudor,
Technoport Schlassgoart,
66 rue de Luxembourg,
P.O. BOX 144,
L-4002 Esch-sur-Alzette, Luxembourg
<christian.braun <at> tudor.lu> writes:
Hi to all members of the list,I have problems with v.out.ogr writing to
PostGIS.We have set up a GRASS location with EPSG:2169 for Luxembourg. If I want
spatial_ref_sys will be created because the parameters in GRASS doesn't match
be fine but I want to avoid a real mess in PostGIS.A first solution is to reset
not a thing I want to do for every time I export a layer.Are there any
possibilities for a workaround? Maybe to set a SRID with v.out.ogr?Thanks in
advance,Christian_________________________________________Dipl. Geogr. Christian
BraunTel: +352- 425991-608Mobil: +49-179-6845896Mail: christian.braun
<at>
tudor.luResource Centre for Environmental Technologies,Public Research Centre
Henri Tudor,Technoport Schlassgoart,66 rue de Luxembourg,P.O. BOX 144,L-4002
grassuser mailing list
grassuser <at> grass.itc.it
Use shp2pgsql -s <srid> (dump your data to shapefile first). I agree, I don't
like how OGR likes to make new SRID's.
THK
