[GRASS-user] ERROR 1: TIFFOpen: No error Using GDAL data type <Byte>
I am using "r.out.gdal" function within a Python script through the command
console of grass7.
I am calling it by doing:
from grass.script.core import run_command
run_command("r.out.gdal",
        flags="c",
        type="Byte",
        input="prova"+ str(m+1),
        output=outFolder+ "\prova"+ str(m+1)+ ".tif",
        nodata=255)
I am getting this error:
ERROR 1: TIFFOpen:D:\UMBE\PhD\Nepal\khumbu_article\shadow
_sun_hourly\prova_hourly_shadow\prova1.tif: No error
ERROR: Impossibile creare il dataset
<D:\UMBE\PhD\Nepal\khumbu_article\shadow
_sun_hourly\prova_hourly_shadow\prova1.tif> usando il driver <GTiff>
  File "D:\UMBE\PhD\Nepal\khumbu_article\shadow\r_sun_hourly
\prova_r-sun-hourly.py", line 39, in <module>
    nodata=255)
  File "C:\OSGeo4W\apps\grass\grass-7.0.0\etc\python\grass\s
cript\core.py", line 375, in run_command
    return handle_errors(returncode, returncode, args,
kwargs)
cript\core.py", line 310, in handle_errors
    returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['r.out.gdal', '-c', 'output=D:\\UMBE\\PhD\\Nepal\\khumbu_ar
ticle\\shadow\r_sun_hourly\\prova_hourly_shadow\\prova1.tif'
, 'nodata=255', 'type=Byte', 'input=prova1'] ended with
error
Process ended with non-zero return code 1. See errors in the
(error) output.
Anyway, if I use the same call from the command line (not calling the Python
script) I have my "prova1.tif" written correctly in the folder I chose. Why?
Any guess?
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-1-TIFFOpen-No-error-Using-GDAL-data-type-Byte-tp5200187.html
Maybe ...
outFolder is not correctly defined, python wants slash (/) in path definition
console of grass7.
        flags="c",
        type="Byte",
        nodata=255)
     nodata=255)
kwargs)
error
(error) output.
Any guess?
grass-user mailing list
grass-user@lists.osgeo.org
I think you're somehow getting a newline character into the output path. See below.
Try using the native python os.path.join(...) to create an output variable and avoid any use of string concatenation within the run_command statement (including the input varialbe)
console of grass7.
        flags="c",
        type="Byte",
        nodata=255)
     nodata=255)
kwargs)
Note the '\r' between shadow and _sun
error
(error) output.
Any guess?
This mail was received via Mail-SeCure System.
Thank you so much. Indeed, the problem were those slashes.
Now I am using this line of code as suggested (with a slight addition
("os.sep") to make it work on a Windows machine):
outFolder=
os.path.join("D:",os.sep,"UMBE","PhD","Nepal","khumbu_article","shadow","r_sun_hourly","prova_hourly_shadow")
        flags="c",
        type="Byte",
        output=os.path.join(outFolder,"prova"+ str(m+1)+ ".tif"),
        nodata=255)
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-1-TIFFOpen-No-error-Using-GDAL-data-type-Byte-tp5200187p5200218.html
yes, mutch better :slight_smile:
outFolder=
        flags="c",
        type="Byte",
        nodata=255)
