[GRASS-user] [ERROR 4:unable to open EPSG support file gcs.csv]
Hi users,
I am trying to produce basin shape-file and then save in desktop in new directory with python script. Interestingly, it gets welly executed in my PC as expected. However, with the same script following error is thrown in my laptop.
r.to.vect complete
ERROR 4:Unable to open EPSG support file gcs.csv.
Try setting the GDAL_DATA environment variable to point to the directory containing EPSG csv files.
ERROR: Unknown EPSG code 32645
The projection system that I am working is:
name: WGS 84 / UTM zone 45N
datum: wgs84
ellps: wgs84
proj: utm
zone: 45
My laptop processor is AMD 64-bit processor and PC is i7 series 64 bit processor. The grass 7.2.0 on both system.
Any solution will be much appreciated.
Best,
Ang Dawa Sherpa
Ang Sherpa wrote
Hi users,
my laptop.
r.to.vect complete
datum: wgs84
ellps: wgs84
proj: utm
zone: 45
*Best,*
*Ang Dawa Sherpa*
grass-user mailing list
grass-user@.osgeo
This may be an issue of your GDAL installation.
Which OS are you using? Linux? Windows? Mac?
Running gdal-config --datadir shows where GDAL searches for gcs.csv.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp5313117p5313118.html
[please keep it on the mailing list! others can help and others can benefit from the answers!]
I am using windows 10 * 64-bit processor in my PC and windows 8 * 64 bit processor in my laptop.
Running gdal-config --datadir throws error:
'gdal-config' is not recognized as an internal or external command,
operable program or batch file.
OK; in winGRASS, there is no gdal-config, thus the error.
which winGRASS are you using? standalone-winGRASS 7.2.0? OSGeo4W-winGRASS 7.2.0?
testing it here with:
System Info
GRASS version: 7.2.0
GRASS SVN revision: r70156
Build date: 2016-12-29
Build platform: i386-w64-mingw32
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
typing in the winGRASS-windows console:
C:\>echo %GDAL_DATA%
C:\OSGeo4W\share\gdal
here the %GDAL_DATA% variable points to the correct path.
try the same on both your working and not working system and report the differences.
kind regards
Helmut
Gesendet: Montag, 20. März 2017 um 08:31 Uhr
Betreff: Re: [GRASS-user] [ERROR 4:unable to open EPSG support file gcs.csv]
Best,
On Mon, Mar 20, 2017 at 12:07 PM, Helmut Kudrnovsky <hellik@web.de[mailto:hellik@web.de]> wrote:Ang Sherpa wrote
Hi users,
my laptop.
r.to.vect complete
datum: wgs84
ellps: wgs84
proj: utm
zone: 45
*Best,*
*Ang Dawa Sherpa*
grass-user@.osgeo
best regards
Helmut
grass-user@lists.osgeo.org[mailto:grass-user@lists.osgeo.org]
Thanks Helmut,
I am using standalone-winGRASS 7.2.0
In both my PC and laptop when: echo %GDAL_DATA% is executed in winGRASS-console it shows the same location:
c:\Program Files\GRASS GIS 7.2.0\Share\gdal
Ang Sherpa wrote
Thanks Helmut,
could you have a look if gcs.csv lives in the folder above?
may you re-install your winGRASS standalone-winGRASS 7.2.0?
may you try OSGeo4W-winGRASS 7.2.0 (https://trac.osgeo.org/osgeo4w/)?
can't reproduce the error here at the moment.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp5313117p5313354.html
Yes, gcs.csv exists in both machine. Well, I reinstalled Grass 7.2 and it worked.
Thanks.
On Tue, Mar 21, 2017 at 3:23 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
Ang Sherpa wrote
Thanks Helmut,
can’t reproduce the error here at the moment.
best regards
Helmut
Ang Dawa Sherpa
GIS technician - Irrigation Master Plan
WRPPF - DOI, Nepal Government
Lalitpur
contact: 984 007 3861
Hi users,
When I tried adding C:\Program Files\GRASS GIS 7.2.0\share\gdal to the system path with following line of code, it doesnot work as expected. Am I missing something?
My code is
new_path = r’C:\Program Files\GRASS GIS 7.2.0\share\gdal’
os.environ[‘PATH’] += os.pathsep + new_path
Still this error persist.
Best,
Ang Dawa Sherpa
Thanks.
Ang Dawa Sherpa
Lalitpur
Ang Sherpa wrote
Thanks Helmut,
best regards
Helmut
Ang Sherpa wrote
Hi users,
missing something?
My code is
new_path = r'C:\Program Files\GRASS GIS 7.2.0\share\gdal'
os.environ['PATH'] += os.pathsep + new_path
*Best,*
*Ang Dawa Sherpa*
On Tue, Mar 21, 2017 at 3:36 PM, Ang Sherpa &lt;
angsherpa232@
worked.
Thanks.
*Regards,*
*Ang Dawa Sherpa*
*GIS technician - Irrigation Master Plan*
*WRPPF - DOI, Nepal Government*
*Lalitpur*
*contact: 984 007 3861*
On Tue, Mar 21, 2017 at 3:23 PM, Helmut Kudrnovsky &lt;
hellik@
&gt; wrote:
Ang Sherpa wrote
> Thanks Helmut,
best regards
Helmut
3117p5313354.html
grass-user@.osgeo
grass-user@.osgeo
AFAIK adding the gdal related folder to %PATH% doesn't help.
As mentioned in the error message, the variable %GDAL_DATA%
should be defined in your script.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp5313117p5314199.html
Thanks for attention,
Tried everything I could. Any solution to incorporate %GDAL_DATA% in the script, other than to manually adding GDAL_DATA path in system variable?
On Sat, Mar 25, 2017 at 4:02 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
Ang Sherpa wrote
Hi users,
missing something?
My code is
Best,
Ang Dawa Sherpa
angsherpa232@
worked.
Thanks.
Ang Dawa Sherpa
Lalitpur
hellik@
> wrote:
Ang Sherpa wrote
Thanks Helmut,
best regards
Helmut
3117p5313354.html
grass-user@.osgeo
grass-user@.osgeo
AFAIK adding the gdal related folder to %PATH% doesn’t help.
best regards
Helmut
Best,
Ang Dawa Sherpa
*Best,*
*Ang Dawa Sherpa*
On Sat, Mar 25, 2017 at 4:02 PM, Helmut Kudrnovsky &lt;
hellik@
&gt; wrote:
Ang Sherpa wrote
> Hi users,
Am
I
> missing something?
> My code is
directory
> *Best,*
> *Ang Dawa Sherpa*
> angsherpa232@
it
>> worked.
>> Thanks.
>> *Regards,*
>> *Ang Dawa Sherpa*
>> *Lalitpur*
> hellik@
> &gt; wrote:
>>> Ang Sherpa wrote
>>> > Thanks Helmut,
>>> best regards
>>> Helmut
>>> 3117p5313354.html
>>> _______________________________________________
> grass-user@.osgeo
> grass-user@.osgeo
best regards
Helmut
grass-user@.osgeo
grass-user@.osgeo
Are you running your python script inside or outside a GRASS session?
Inside a GRASS session of standalone or osgeo4w wingrass, %GDAL_DATA% is
already defined.
If outside, %GDAL_DATA% may need to be defined when GDAL comes in.
Have you maybe multiple gdal installations on your system?
At
https://grasswiki.osgeo.org/wiki/GRASS_and_Python
there is
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp5313117p5314213.html
fixed by adding
os.environ[‘GDAL_DATA’] = r’C:\Program Files\GRASS GIS 7.2.0\share\gdal’ at the beginning of the script.
Best,
Ang Dawa Sherpa
hellik@
> wrote:
Ang Sherpa wrote
Hi users,
Am
I
missing something?
My code is
directory
Best,
Ang Dawa Sherpa
angsherpa232@
it
worked.
Thanks.
Ang Dawa Sherpa
Lalitpur
hellik@
> wrote:
Ang Sherpa wrote
Thanks Helmut,
best regards
Helmut
3117p5313354.html
grass-user@.osgeo
grass-user@.osgeo
best regards
Helmut
grass-user@.osgeo
grass-user@.osgeo
already defined.
At
there is
best regards
Helmut
Best,
Ang Dawa Sherpa
Ang Sherpa wrote
fixed by adding
os.environ['GDAL_DATA'] = r'C:\Program Files\GRASS GIS 7.2.0\share\gdal'
at
anything what sould be added to the wiki
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp5313117p5314372.html
