for some weeks now, when compiling grass64_release on my debian 64 bit
Squeeze, make encounters errors :
Errors in:
/usr/local/src/grass64_release/lib/ogsf
/usr/local/src/grass64_release/lib/nviz
/usr/local/src/grass64_release/misc/m.nviz.image
/usr/local/src/grass64_release/visualization/nviz
Making little use of nviz, it is not an emergency but I'd like to fix it
now. I fear the problem has something to do with avformat libs.
I tried to cd to lib/ogsf, then make clean, then make. The following
error occurs :
In file included from gsd_img_mpeg.c:28:
/usr/include/libavformat/avformat.h:158: warning: ‘AVMetadata’
is deprecated
gsd_img_mpeg.c: In function ‘add_video_stream’:
gsd_img_mpeg.c:64: warning: assignment makes pointer from
integer without a cast
gsd_img_mpeg.c: In function ‘gsd_init_mpeg’:
gsd_img_mpeg.c:375: error: ‘AVIO_FLAG_WRITE’ undeclared (first
use in this function)
gsd_img_mpeg.c:375: error: (Each undeclared identifier is
reported only once
gsd_img_mpeg.c:375: error: for each function it appears in.)
make: *** [OBJ.x86_64-unknown-linux-gnu/gsd_img_mpeg.o] Erreur 1
The current version of libavformat-dev is 5:0.7.15-dmo1
Can anyone help me with this issue ? should I try to force a more recent
version of the lib, or is the problem somewhere else ?
Thank you,
Vincent
reported only once
If you don't need the ability to write video files, don't use
--with-ffmpeg.
Otherwise, you'll need a more recent version of the libraries.
Thank you Glynn for your answer, I'll trim my configure command.
If I ever need to output video, what is the minimum version of avcodec
to build against ?
Vincent
> reported only once
--with-ffmpeg.
to build against ?
I don't know.
Actually, the OSGF library attempts to support older versions:
#if LIBAVFORMAT_VERSION_INT < AV_VERSION_INT(52, 100, 0)
if (url_fopen(&oc->pb, filename, URL_WRONLY) < 0) {
#else
if (avio_open(&oc->pb, filename, AVIO_FLAG_WRITE) < 0) {
#endif
So it will use the old API for versions of libavformat prior to
52.100.0.
Presumably that version number should be higher; your error message
suggest that you're using a newer version but which doesn't define the
newer macro.
I have no idea how the package versions (e.g. 5:0.7.15-dmo1)
correspond to ffmpeg's internal version numbers. E.g. here I have
ffmpeg-0.10.3, which has:
Library Version Defined in header
libavutil 51.35.100 libavutil/avutil.h
libavformat 53.32.100 libavformat/version.h
libavcodec 53.61.100 libavcodec/version.h
libavdevice 53.4.100 libavdevice/avdevice.h
libavfilter 2.61.100 libavfilter/version.h
Perhaps I should downgrade (force older version) ffmpeg, to get in the
first case of the if loop.
Here's the result of ffmpeg --version on my box:
ffmpeg version 0.7.15, Copyright (c) 2000-2013 the FFmpeg
developers
built on Feb 22 2013 07:18:58 with gcc 4.4.5
configuration: --enable-libdc1394 --prefix=/usr
--extra-cflags='-Wall -g ' --cc='ccache cc' --enable-shared
--enable-libmp3lame --enable-gpl --enable-libvorbis
--enable-pthreads --enable-libfaac --enable-libxvid
--enable-postproc --enable-x11grab --enable-libgsm
--enable-libtheora --enable-libopencore-amrnb
--enable-libopencore-amrwb --enable-libx264 --enable-libspeex
--enable-nonfree --disable-stripping --enable-avfilter
--enable-libdirac --disable-decoder=libdirac
--enable-libfreetype --enable-libschroedinger
--disable-encoder=libschroedinger --enable-version3
--enable-libopenjpeg --enable-libvpx --enable-librtmp
--extra-libs=-lgcrypt --disable-altivec --disable-armv5te
--disable-armv6 --disable-vis
libavutil 50. 43. 0 / 50. 43. 0
libavcodec 52.123. 0 / 52.123. 0
libavformat 52.111. 0 / 52.111. 0
libavdevice 52. 5. 0 / 52. 5. 0
libavfilter 1. 80. 0 / 1. 80. 0
libswscale 0. 14. 1 / 0. 14. 1
libpostproc 51. 2. 0 / 51. 2. 0
Vincent.
> to build against ?
I don't know.
#else
#endif
52.100.0.
newer macro.
[previous discussion deleted]
Just adding to that (old) thread (but still valid):
Recently, the same "osgf" error showed-up in Ubuntu, in both attempts
compiling G64 and G7.
The current
ffmpeg --version
ffmpeg version 0.8.6-6:0.8.6-1ubuntu2, Copyright (c) 2000-2013 the Libav
developers built on Mar 30 2013 22:20:06 with gcc 4.7.2
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a
future release. Please use avconv instead.
Missing argument for option '-version'
and
avconv --version
avconv version 0.8.6-6:0.8.6-1ubuntu2, Copyright (c) 2000-2013 the Libav
Nikos
