[GRASS-user] Error building v.label.sa in Grass 6.5
I'm running into an error building v.label.sa using today's svn checkout
of Grass 6.5, rev 37569.
Changing directory to grass6_devel/vector/v.label.sa and running make
clean then make results in:
$ make
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p OBJ.x86_64-unknown-linux-gnu
gcc -I/usr/local/grass6_devel/dist.x86_64-unknown-linux-gnu/include -g -O2 -I/usr/local/include -I/usr/local/include -DPACKAGE=\""grassmods"\" -I/usr/local/grass6_devel/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/annealing.o -c annealing.c
In file included from labels.h:20,
                 from annealing.c:15:
/usr/include/ft2build.h:56:38: error: freetype/config/ftheader.h: No such file or directory
In file included from annealing.c:15:
labels.h:21:10: error: #include expects "FILENAME" or <FILENAME>
labels.h:22:10: error: #include expects "FILENAME" or <FILENAME>
make: *** [OBJ.x86_64-unknown-linux-gnu/annealing.o] Error 1
Eric Patton
$ make
To make the header visible to GRASS on my system, I have to configure:
./configure [...] --with-freetype
--with-freetype-includes=/usr/include/freetype2
I fiexed the vector makefile to only build v.label.sa if freetype is
enabled in develbranch_6.
--Wolf
$ make
grass-user mailing list
grass-user@lists.osgeo.org
Wolf Bergenheim (wolf+grass@bergenheim.net)
