[GRASS-user] ERROR : "child process exited abnormally"
i have installed grass on windows online setup.
when i m running “g:\cygwin\grass.bat” it display some errors as:
command not found_profile: line 2:
command not found_profile: line 5:
command not found_profile: line 8:
command not found_profile: line 14:
command not found_profile: line 16:
/home/databasedir/.bash_profile line 47: syntax error: unexpected end of the cleaning up temporary files…
Starting GRASS…ERROR: LOCATION<< /home/databasedir/2388.tmp >> not available
And if i am creating any new location from EPSG it does not creates.
How can i resolve the issue.
Then i have replaced the old version with gdal1.3 and grass 6.2 and i m
having Spearfish6. now my project location is ‘Spearfish60’ and mapset is
‘PERMANENT’
the error after clicking on ‘ENTER GRASS’ is
“child process exited abnormally”
I need the GRASS on windows. I hope it will work with windows XP.
Pawan Joshi
0120-4314870
G-5, Sector 20
Noida
“Do what you love @};- , Love what you do.”
Cheap Talk? Check out Yahoo! Messenger’s low PC-to-Phone call rates.
when i m running "g:\cygwin\grass.bat" it display some errors as:
of the cleaning up temporary files...... Starting GRASS....ERROR:
[Cygwin GRASS 6.1-cvs binaries from April]
I can't help with that, beyond noting that "grass.bat" from the GRASS
6.1-cvs version should not be used with the GRASS 6.2.1 binaries.
i m having Spearfish6. now my project location is 'Spearfish60' and
mapset is 'PERMANENT'
  the error after clicking on 'ENTER GRASS' is
see
  http://grass.ibiblio.org/grass62/binary/mswindows/
follow the "Troubleshooting" instructions there (cygcheck) and please
reply to the list what you find out so others with the same problem may
benefit.
it will.
Hamish
