Dear list,
I am trying to compile grass 7.8.2 on an HPC cluster using centos 7 as operative system. I can not install binaries. I need to compile from source.
The python version I am using is Python 3.7.4
The configure and the make are working fine. However I get the following errors at the make install stage:
rm /home/user/grass//grass78/etc/fontcap
rm: cannot remove ‘/home/user/grass//grass78/etc/fontcap’: No such file or directory
make[1]: [real-install] Error 1 (ignored)
make /home/user/grass//grass78/etc/fontcap
make[2]: Entering directory /home/user/grass/grass-7.8.2' make[2]: *** No rule to make target
/home/user/grass/grass-7.8.2/dist.x86_64-pc-linux-gnu/etc/fontcap’, needed by /home/user/grass//grass78/etc/fontcap'. Stop. make[2]: Leaving directory
/home/user/grass/grass-7.8.2’
make[1]: *** [real-install] Error 2
make[1]: Leaving directory `/home/user/grass/grass-7.8.2’
make: *** [install] Error 2
Am I missing some dependencies in the fonts?
Is the python version ok or should I use a slightly older 3.x one?
are there any recommendations for the gcc version to use?
Thank you very much for your help in advance.
Best wishes
Laura
neteler
December 19, 2019, 10:36pm
2
On Thu, Dec 19, 2019 at 8:12 AM Laura Poggio <laura.poggio@gmail.com> wrote:
Dear list,
Just to understand: for policy reasons?
Importantly, pls post your "configure" command to better understand
the error below:
make[2]: Entering directory `/home/user/grass/grass-7.8.2'
make[2]: *** No rule to make target `/home/user/grass/grass-7.8.2/dist.x86_64-pc-linux-gnu/etc/fontcap', needed by `/home/user/grass//grass78/etc/fontcap'. Stop.
make[2]: Leaving directory `/home/user/grass/grass-7.8.2'
make[1]: Leaving directory `/home/user/grass/grass-7.8.2'
... probably in the configure step.
That should be fine.
No special recommendations.
Best wishes
Dear Markus,
thanks
Below my configure (grass 7.6.1 compiles fine with a similar configure.)
./configure
-prefix=/home/user/grass/
–enable-64bit --with-fftw-includes=/cm/shared/apps/fftw/openmpi/gcc/64/3.3.7/include/
–with-fftw-libs=/cm/shared/apps/fftw/openmpi/gcc/64/3.3.7/lib/
–with-freetype-includes=/home/user/grass/freetypes/freetype-2.9.1/include/
–with-netcdf --with-geos --with-blas --with-lapack --with-postgres
–with-zstd-libs=/home/user/grass/zstd/zstd-1.4.0/lib/
–with-zstd-includes=/home/user/grass/zstd/zstd-1.4.0/lib/
The freetype and zstd are in my home because they are not available on the cluster, so I had to create them locally.
If I may, I add an additional question: which is the right option in configure to point to a specific version of proj? --with-proj-libs?
Thanks a lot
Laura
On Thu, 19 Dec 2019 at 23:36, Markus Neteler <neteler@osgeo.org > wrote:
On Thu, Dec 19, 2019 at 8:12 AM Laura Poggio <laura.poggio@gmail.com > wrote:
Dear list,
Importantly, pls post your “configure” command to better understand
the error below:
… probably in the configure step.
Best wishes
On Fri, Dec 20, 2019 at 7:47 AM Laura Poggio <laura.poggio@gmail.com > wrote:
Dear Markus,
thanks
./configure \
-prefix=/home/user/grass/ \
is it possible that prefix and path to the GRASS source are identical? This will not work and cause errors when running “make install”. In this case, prefix must be set to another location, e.g. /home/user/local if you do not want or can not use the default /usr/local.
Just a guess,
Markus M
Thanks a lot
Laura
Dear list,
the error below:
Best wishes
grass-user mailing list
grass-user@lists.osgeo.org
Dear Markus,
the path to the GRASS source (the directory where I compile) is
I get the same when I try to compile with -prefix=/home/user/local/
Thanks!
Laura
On Fri, 20 Dec 2019 at 09:22, Markus Metz <markus.metz.giswork@gmail.com > wrote:
Dear Markus,
thanks
./configure \
Just a guess,
Markus M
Thanks a lot
Laura
Dear list,
the error below:
Best wishes
Dear all,
I managed to remove the error by specifying --without-zstd.
Thanks a lot!
Laura
On Fri, 20 Dec 2019 at 10:48, Laura Poggio <laura.poggio@gmail.com > wrote:
Dear Markus,
Thanks!
Laura
Dear Markus,
thanks
./configure \
Just a guess,
Markus M
Thanks a lot
Laura
Dear list,
the error below:
Best wishes
On Fri, Dec 20, 2019 at 12:03 PM Laura Poggio <laura.poggio@gmail.com > wrote:
Dear all,
is it possible that your custom path to zstd libs
is not in LD_LIBRARY_PATH?
That would explain it.
Markus M
Thanks a lot!
Laura
Dear Markus,
Thanks!
Laura
Dear Markus,
thanks
./configure
Just a guess,
Markus M
Thanks a lot
Laura
Dear list,
the error below:
Best wishes
And this sorted the problem. Compiled with the zstd libraries as well and no errors.
Thank you very much!
Laura
On Fri, 20 Dec 2019 at 13:14, Markus Metz <markus.metz.giswork@gmail.com > wrote:
Dear all,
Markus M
Thanks a lot!
Laura
Dear Markus,
Thanks!
Laura
Dear Markus,
thanks
./configure
Just a guess,
Markus M
Thanks a lot
Laura
Dear list,
the error below:
Best wishes
