punkish@Lucknow /usr/local/lib$nm libproj.dylib | grep 'pj_get_def'
00027210 T _pj_get_def
To summarize, I have PROJ.4 4.6.1 installed correctly, and working
well with other programs such as MapServer and PostGIS. My libproj has
that specific symbol that GRASS configure seems unable to find. I have
seen a few references to this error around on lists, but no definitive
remedy.
On Thu, Sep 3, 2009 at 2:23 PM, Markus Neteler<neteler@osgeo.org> wrote:
On Thu, Sep 3, 2009 at 2:58 PM, P Kishor<punk.kish@gmail.com> wrote:
I am trying to compile GRASS on Mac OS X. For now, configure is
failing to find libproj correctly. Here is what I get
punkish@Lucknow ~/Projects/grass-6.4.0RC5$ ./configure \
--with-proj-includes=/usr/local/include \
--with-proj-libs=/usr/local/lib \
--with-proj-share=/usr/local/share/proj \
checking for location of External PROJ.4 includes... /usr/local/include
checking for proj_api.h... yes
checking External PROJ.4 version... 461
checking for location of External PROJ.4 library... /usr/local/lib
checking for pj_get_def in -lproj... no
configure: error: *** Unable to locate External PROJ.4 library.
In config.log (at bottom) some details should be shown why the
pj_get_def test fails.
Thanks Markus. This is what I have
punkish@Lucknow ~/Projects/grass-6.4.0RC5$tail -20 config.log
configure:7025: checking for location of External PROJ.4 library
configure:7050: checking for pj_get_def in -lproj
configure:7067: gcc -o conftest -arch x86_64 -Os -L/usr/local/lib
-arch x86_64 -arch x86_64 conftest.c -lproj 1>&5
ld warning: in /usr/local/lib/libproj.dylib, file is not of required
architecture
Undefined symbols:
"_pj_get_def", referenced from:
_main in ccjErGbn.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
configure: failed program was: #line 7056 "configure" #include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char pj_get_def();
architecture
This will be the problem: "file is not of required architecture"
I have no clue about MacOSX, though. On Linux, it would be
a 32bit/64bit mixture...
Undefined symbols:
_main in ccjErGbn.o
char pj_get_def();
architecture
I compiled PROJ.4 with the standard instructions, nothing fancy at
all. It has worked fine with MapServer, PostGIS, GDAL and GEOS
installations so far. GRASS is the only one choking up with the "file
is not of required architecture" message, so I am loath to tinker with
what works with 4 other programs just so it can possibly work with one
other program, and possibly break the other four.
I will try again without those flags and report back.
Undefined symbols:
_main in ccjErGbn.o
char pj_get_def();
architecture
Ok. Results of a quick test... unsetting those CFLAGS and CXXFLAGS did
the trick. Of course, then configure got hung up on readline
(history), so I had to configure it without-readline. Now it is
make-ing.
Undefined symbols:
_main in ccjErGbn.o
char pj_get_def();
architecture
