[GRASS-user] error compiling grass65svn and addons for grass64
Dear all,
I installed grass6.4 on a machine with Suse11.2 64 bit from the official repository. Then I tried to install some addons with g.extension and using the usual configure/make/make install.
In both cases I get the following error:
make: *** [OBJ.x86_64-unknown-linux-gnu/[…]] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
I also tried to compile grass65 from svn and I am getting the same error.
Please let me know and I can provide more details. Sorry but I do not know what would be useful for better understanding the problem.
Thank you very much in advance
Laura
Hello,
You have to provide whole error message. Without exact error text,
it's impossible to tell what kind of problem You have.
WBR,
Maris.
2010/10/20, Laura Poggio <laura.poggio@gmail.com>:
Dear all,
make: *** [OBJ.x86_64-unknown-linux-gnu/[...]] Error 1
Laura
Have you got the following packges installed?
gcc
g++
make
Sab
Hello,
WBR,
Maris.
Dear all,
using
error.
know
Laura
grass-user mailing list
grass-user@lists.osgeo.org
Yes I have gcc, g++, make.
The full error message for one extension is pasted below (for one extension as example).
Thank you very much
Laura
Checked out revision 43978.
Compiling <r.stream.basins>…
In file included from catchment.c:1:
global.h:5:23: error: grass/gis.h: No such file or directory
global.h:6:24: error: grass/Vect.h: No such file or
directory
global.h:7:27: error: grass/glocale.h: No such file or
directory
global.h:64: error: expected ‘=’, ‘,’, ‘;’,
‘asm’ or ‘attribute’ before ‘*’ token
catchment.c: In function ‘find_outlets’:
catchment.c:29: warning: cast to pointer from integer of
different size
catchment.c:36: error: ‘streams’ undeclared (first use
in this function)
catchment.c:36: error: (Each undeclared identifier is
reported only once
catchment.c:36: error: for each function it appears in.)
catchment.c:45: warning: cast to pointer from integer of
different size
catchment.c:48: error: ‘dirs’ undeclared (first use in
this function)
catchment.c: In function ‘reset_catchments’:
catchment.c:115: error: ‘streams’ undeclared (first use
in this function)
catchment.c: In function ‘fill_catchments’:
catchment.c:147: error: ‘streams’ undeclared (first use
in this function)
catchment.c:159: error: ‘dirs’ undeclared (first use in
this function)
make: *** [OBJ.x86_64-unknown-linux-gnu/catchment.o] Error 1
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p OBJ.x86_64-unknown-linux-gnu
gcc -I/usr/src/packages/BUILD/grass-6.4.0/dist.x86_64-unknown-linux-gnu/include -O2 -I/usr/include/gdal/ -DPACKAGE="“grassmods”" -I/usr/src/packages/BUILD/grass-6.4.0/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/catchment.o -c catchment.c
(Wed Oct 20 11:56:21 2010) Command finished (6 sec)
gcc
g++
make
Sab
Hello,
it’s impossible to tell what kind of problem You have.
WBR,
Maris.
Dear all,
using
error.
know
Laura
Hello,
if SUSE provides separate -dev packages, install grass-dev package.
Then You have to run Your make commands with
MODULE_TOPDIR=/path/to/grass.
See this issue for details: http://trac.osgeo.org/grass/ticket/620
Still error You had when compiling 6.5 from source must be a different
one, as provided error message makes sense only to addons and not
compilation of whole GRASS.
Maris.
as example).
Thank you very much
Laura
Compiling <r.stream.basins>...
directory
directory
‘asm’ or ‘__attribute__’ before ‘*’ token
different size
in this function)
reported only once
different size
this function)
in this function)
in this function)
this function)
gcc
-O2 -I/usr/include/gdal/ -DPACKAGE=\""grassmods"\"
sec)
gcc
g++
make
Sab
> Hello,
> WBR,
> Maris.
>> Dear all,
>> official
>> using
>> error.
>> know
>> Laura
grass-devel is installed. Below the error message is I try to use make with MODULE_TOPDIR=/path/to/grass instead of g.extension.
thank you very much!
Laura
gcc -I/usr/src/packages/BUILD/grass-6.4.0/dist.x86_64-unknown-linux-gnu/include -O2 -I/usr/include/gdal/ -DPACKAGE="“grassmods”" -I/usr/src/packages/BUILD/grass-6.4.0/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/io.o -c io.c
io.c:1:27: error: grass/glocale.h: No such file or directory
In file included from io.c:2:
global.h:6:24: error: grass/Vect.h: No such file or directory
global.h:7:24: error: grass/dbmi.h: No such file or directory
global.h:80: error: expected ‘)’ before ‘’ token
global.h:81: error: expected ‘)’ before ‘
’ token
global.h:93: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘’ token
global.h:94: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘
’ token
io.c: In function ‘open_raster’:
io.c:8: error: storage size of ‘cellhd’ isn’t known
io.c:10: warning: assignment makes pointer from integer without a cast
io.c:16: error: ‘CELL_TYPE’ undeclared (first use in this function)
io.c:16: error: (Each undeclared identifier is reported only once
io.c:16: error: for each function it appears in.)
io.c:26: error: invalid use of undefined type ‘struct Cell_head’
io.c: In function ‘create_base_maps’:
io.c:37: error: ‘CELL’ undeclared (first use in this function)
io.c:37: error: ‘r_dirs’ undeclared (first use in this function)
io.c:37: error: ‘r_streams’ undeclared (first use in this function)
io.c:38: error: ‘DCELL’ undeclared (first use in this function)
io.c:38: error: ‘r_accum’ undeclared (first use in this function)
io.c:47: error: ‘dirs’ undeclared (first use in this function)
io.c:47: error: expected expression before ‘)’ token
io.c:48: error: ‘streams’ undeclared (first use in this function)
io.c:48: error: expected expression before ‘)’ token
io.c:50: error: ‘accum’ undeclared (first use in this function)
io.c:50: error: expected expression before ‘)’ token
io.c:52: error: expected expression before ‘)’ token
io.c:53: error: expected expression before ‘)’ token
io.c:55: error: expected expression before ‘)’ token
io.c:73: error: expected expression before ‘)’ token
io.c: In function ‘stream_number’:
io.c:120: error: ‘CELL’ undeclared (first use in this function)
io.c:120: error: expected ‘;’ before ‘c_min’
io.c:121: error: storage size of ‘stream_range’ isn’t known
io.c:124: warning: assignment makes pointer from integer without a cast
io.c:126: error: ‘c_min’ undeclared (first use in this function)
io.c:126: error: ‘c_max’ undeclared (first use in this function)
io.c: In function ‘write_maps’:
io.c:136: error: ‘CELL’ undeclared (first use in this function)
io.c:136: error: ‘strahler_buf’ undeclared (first use in this function)
io.c:136: error: ‘shreeve_buf’ undeclared (first use in this function)
io.c:136: error: ‘hack_buf’ undeclared (first use in this function)
io.c:136: error: ‘horton_buf’ undeclared (first use in this function)
io.c:136: error: ‘topo_buf’ undeclared (first use in this function)
io.c:138: error: storage size of ‘history’ isn’t known
io.c:142: error: ‘CELL_TYPE’ undeclared (first use in this function)
io.c:190: error: ‘streams’ undeclared (first use in this function)
io.c: In function ‘create_table’:
io.c:285: error: ‘dbConnection’ undeclared (first use in this function)
io.c:285: error: expected ‘;’ before ‘conn’
io.c:286: error: ‘dbDriver’ undeclared (first use in this function)
io.c:286: error: ‘driver’ undeclared (first use in this function)
io.c:287: error: ‘dbHandle’ undeclared (first use in this function)
io.c:287: error: expected ‘;’ before ‘handle’
io.c:288: error: ‘dbString’ undeclared (first use in this function)
io.c:288: error: expected ‘;’ before ‘table_name’
io.c:334: error: ‘db_sql’ undeclared (first use in this function)
io.c:335: error: ‘val_string’ undeclared (first use in this function)
io.c:336: error: ‘table_name’ undeclared (first use in this function)
io.c:337: error: ‘handle’ undeclared (first use in this function)
io.c:341: error: ‘conn’ undeclared (first use in this function)
io.c:383: error: ‘DB_OK’ undeclared (first use in this function)
io.c:393: error: ‘DB_PRIV_SELECT’ undeclared (first use in this function)
io.c:393: error: ‘DB_GROUP’ undeclared (first use in this function)
io.c:393: error: ‘DB_PUBLIC’ undeclared (first use in this function)
make: *** [OBJ.x86_64-unknown-linux-gnu/io.o] Error 1
On 20 October 2010 16:45, Maris Nartiss <maris.gis@gmail.com> wrote:
Hello,
Maris.
as example).
Thank you very much
Laura
directory
directory
different size
in this function)
reported only once
different size
this function)
in this function)
in this function)
this function)
gcc
sec)
gcc
g++
make
Sab
Hello,
WBR,
Maris.
Dear all,
official
using
error.
know
Laura
Hello,
You need to edit /path/to/grass/include/Make/Platform.make file (may
need a root for GRASS installed from packages) and change line
"GRASS_HOME" to point to /path/to/grass. Look around that file and
check that other paths also point to existing files and not some
/usr/src/packages/BUILD nonsense.
If You plan to use custom modules (add-ons etc.) I strongly suggest to
compile GRASS from source. You can run GRASS directly from source
directory (no make install required) and easy update it via "svn up"
to get latest fixes. Easy compilation of addons might be fixed at
6.4.1 time, still it's not today.
Good luck,
Maris.
2010/10/21, Laura Poggio <laura.poggio@gmail.com>:
Laura
gcc
io.c
directory
io.c:2:
directory
directory
directory
io.c:2:
global.h:80: error: expected ‘)’ before ‘*’
token
global.h:81: error: expected ‘)’ before ‘*’
token
io.c:2:
global.h:93: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
token
global.h:94: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
token
io.c: In function
‘open_raster’:
known
cast
function)
once
in.)
Cell_head’
Cell_head’
io.c: In function
‘create_base_maps’:
function)
function)
function)
function)
function)
function)
token
function)
token
function)
token
token
token
token
Hello,
Maris.
extension
> as example).
> Thank you very much
> Laura
> directory
> directory
> different size
> in this function)
> reported only once
> different size
> this function)
> in this function)
> in this function)
> this function)
> gcc
> sec)
>> gcc
>> g++
>> make
>> Cheers
>> Sab
>> > Hello,
>> > WBR,
>> > Maris.
>> >> Dear all,
>> >> official
>> >> and
>> >> using
>> >> error.
>> >> not
>> >> know
>> >> Laura
>> > _______________________________________________
