[GRASS-user] Error creating new mapset
Dear folk,
i have installed GRASS-6.2.3 from source code with no apparent errors during
configuration, compilation and installation. However, when i run grass and
try to create a new mapset i get next error:
g.region: error while loading shared libraries: libgdal.so.1: cannot open
shared object file: Error 40
In fact, when i was setting the projection parameters and chose a UTM
projection, the program did not ask me for the UTM zone, the ellipsoid and
the datum.
In the GRASS configure process I explicitely used the
flag --with-gdal=/usr/local/bin/gdal-config and there were no errors. I
checked for the shared library and it is placed in /usr/local/lib directory.
Before the GRASS installation, I installed the GDAL/OGR bundle from the source
code, with netcdf support, and the GRASS support disabled. Again, there were
no apparent errors. Next I installed the gdal-grass plugin (gdal-grass-1.4.3
with the following options:
configure --with-gdal=/usr/local/bin/gdal-config --with-grass=/usr/local/grass-6.2.3)
I did not detect any problem during the installation of these bundles. Anyone
knows about the problem??
Thanks in advance,
José A. Ruiz
Thanks in advance,
José A. Ruiz
Did you run ldconfig after installing?
~ Eric.
the datum.
Most systems won't load shared libraries from /usr/local/lib without
some additional configuration.
For Linux, you need to either set the LD_LIBRARY_PATH environment
variable to a path which includes /usr/local/lib, or add
/usr/local/lib to /etc/ld.so.conf then run ldconfig (as root).
> during configuration, compilation and installation. However, when i run
> grass and try to create a new mapset i get next error:
> and the datum.
> directory.
> source code, with netcdf support, and the GRASS support disabled. Again,
> there were no apparent errors. Next I installed the gdal-grass plugin
> (gdal-grass-1.4.3 with the following options:
> Anyone knows about the problem??
Thanks a lot for your hints. GRASS is now working.
José A.
