[GRASS-user] Error exporting to tiff
I'm try-ing to export a tiff raster using this couple of commands:
r.composite -c --overwrite red=refl4.hpf@PERMANENT
green=refl3.hpf@PERMANENT blue=refl2.hpf@PERMANENT levels=256
output=hpf
r.out.gdal -c input=hpf@PERMANENT output=/path-to/hpf.tif
format="GTiff" type="Byte"
createopt="INTERLEAVE=PIXEL,TFW=YES,PROFILE=BASELINE,COMPRESS=DEFLATE"
But I have an error:
Checking GDAL data type and nodata value...
2..5..8..11..14..17..20..23..26..29..32..35..38..41..44..47..50..53..56..59..62..65..68..71..74..77..80..83..86..89..92..95..98..100
WARNING: Selected GDAL datatype does not cover data range.
WARNING: GDAL datatype: Byte, range: 0 - 255
WARNING: Raster map <hpf@PERMANENT> range: 0 - 1.67114e+07
WARNING: Raster export results in data loss.
Using GDAL data type <Byte>
Input raster map contains cells with NULL-value (no-data). The value
255 will be used to represent no-data values in the input map. You can
specify a nodata value with the nodata option.
ERROR: Raster export aborted.
The message is absolutely not clear about what is the problem.
I don't know if there some log where retrieve more information.
Many thx for any help.
Thx,
Andrea Peri
qwerty àèìòù
On Wed, Jul 1, 2015 at 8:11 PM, Andrea Peri <aperi2007@gmail.com> wrote:
output=hpf
What is your region setting?
Thx,
Andrea Peri
qwerty àèìòù
grass-user mailing list
grass-user@lists.osgeo.org
I create it from new retrieving the settings from the original geotiff I load.
Actually the region settings are this:
g.region -p
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5058915
south: 4825185
west: 587685
east: 817515
nsres: 30
ewres: 30
rows: 7791
cols: 7661
cells: 59686851
Thx,
2015-07-02 2:24 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
output=hpf
Thx,
Andrea Peri
qwerty àèìòù
Andrea Peri
qwerty àèìòù
I resolve the error.
The original raster to convert was in 16bit value, and before to do
the r.gdal.out is need to rescale to 8 bit.
I wrongly uess the setting BYTE in r.gdal.out was to convert from 16bitto 8 bit.
Instead no, is necessary a convertion using rescale before.
Thx to point me in right direction.
A.
2015-07-02 8:42 GMT+02:00 Andrea Peri <aperi2007@gmail.com>:
g.region -p
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5058915
south: 4825185
west: 587685
east: 817515
nsres: 30
ewres: 30
rows: 7791
cols: 7661
cells: 59686851
Thx,
output=hpf
Thx,
Andrea Peri
qwerty àèìòù
Andrea Peri
qwerty àèìòù
Andrea Peri
qwerty àèìòù
Hi Nikos,
thx for hint,
I try the options Int16, UInt16, Int32 and UInt32,
but always the same error.
A.
2015-07-02 15:21 GMT+02:00 Nikos Alexandris <nik@nikosalexandris.net>:
* Andrea Peri <aperi2007@gmail.com> [2015-07-02 09:26:31 +0200]:
You should have other options (=formats) to export to so as to not
sacrifice the radiometric resolution (16-bit).
Did you try Int16 or UInt16?
Nikos
Andrea Peri
qwerty àèìòù
