Dear all,
I compiled the last svn snapshot (15-08-2009) of Grass 6.4 on a fedora 11 64 bit system with the following options:
-enable-64bit --with-libs=/usr/lib64
–with-cxx --with-glw --with-curses --with-freetype --with-postgres -with-mysql --with-sqlite --with-gdal=/usr/bin/gdal-config --with-python=/usr/bin/python-config --with-wxwidgets=/usr/bin/wx-config --with-proj-share=/usr/share/proj --with-mysql-includes=/usr/include/mysql/ --with-mysql-libs=/usr/lib64/mysql --with-freetype-includes=/usr/include/freetype2
Everything went fine without errors. However when I open GRASS I get the following error:
GRASS 6.4.0svn (DEM):~ > /usr/lib64/python2.6/site-packages/wx-2.8-gtk2-unicode/wx/_core.py:14450: UserWarning: wxPython/wxWidgets release number mismatch
warnings.warn(“wxPython/wxWidgets release number mismatch”)
The gui (wx) is starting, but the 3D view and the digitize do not start. For the 3d view I get a “loading data” message and nothing is happening.
A couple of weeks ago I installed grass on a fedora 10 64 bit with the same options and everything is working fine.
Thank you very much in advance for any hints!
Laura Poggio
