[GRASS-user] error importing rasters
hello to everyone,
when i try to import a raster (i tried more than one) i got the following error (in this case i was importing an ndvi raster):
Failed to run command ‘d.rast map=ndvi_20180715@alessandro’. Details:
GRASS_INFO_WARNING(2682,1): Request for unsupported compressor
GRASS_INFO_END(2682,1)
GRASS_INFO_WARNING(2682,2): Request for unsupported compressor
GRASS_INFO_END(2682,2)
GRASS_INFO_ERROR(2682,3): Request for unsupported compressor
GRASS_INFO_END(2682,3)
Failed to run command ‘d.rast map=imd_2016_32n@alessandro’. Details:
GRASS_INFO_WARNING(2683,1): Request for unsupported compressor
GRASS_INFO_END(2683,1)
GRASS_INFO_WARNING(2683,2): Request for unsupported compressor
GRASS_INFO_END(2683,2)
GRASS_INFO_ERROR(2683,3): Request for unsupported compressor
GRASS_INFO_END(2683,3)
Failed to run command ‘d.rast map=munpm10_average@alessandro’. Details:
GRASS_INFO_WARNING(2684,1): Request for unsupported compressor
GRASS_INFO_END(2684,1)
GRASS_INFO_WARNING(2684,2): Request for unsupported compressor
GRASS_INFO_END(2684,2)
GRASS_INFO_ERROR(2684,3): Request for unsupported compressor
GRASS_INFO_END(2684,3)
i run GRASS on UBUNTU 18.04.2 and i reistalled it yesterday since i was having some troubles using GUI. I’m using version 7.4.0.
does anyone know what’s wrong??
A.
Hi Alessandro,
did you import the rasters in a newer version of GRASS, i.e., 7.6? It seems to me it is not recognizing the compression which is now by default in 7.6, but not in 7.4. I would try to get 7.6 installed again.
For sure others know better
best,
Vero
El jue., 28 mar. 2019 a las 12:38, Alessandro Sebastiani (<alessandro.sebastiani@uniroma1.it>) escribió:
hello to everyone,
A.
grass-user mailing list
grass-user@lists.osgeo.org
Thank you Veronica, it worked!
Il giorno gio 28 mar 2019 alle ore 13:14 Veronica Andreo <veroandreo@gmail.com> ha scritto:
Hi Alessandro,
best,
Vero
hello to everyone,
A.
