[GRASS-user] error in d.slide.show
Hello.
I am a beginner of grass, and linux either.
I have some trouble in using d.slide.show commando.
Could anyone give me a resolution?
I inputted the following commando;
d.mon x0
d.slide.show across=1 down=1 mapset=indochina
I have some raster maps in "indochina" named 0101,0201,0301....
The name of these raster maps was shown one after another at the bottom
of x0 window; however, no raster map was shown.
I also had following error message in the commando prompt.
[0101]
Sorry, <-> is not a valid flag
Sorry, <q> is not a valid flag
Sorry, <u> is not a valid flag
Sorry, <e> is not a valid flag
Sorry, <t> is not a valid flag
Description:
Displays and overlays raster map layers in the active display frame on
the graphics monitor
Keywords:
display
Usage:
d.rast [-oix] map=string [catlist=cat[-cat][,cat[-cat],...]]
   [vallist=val[-val][,val[-val],...]] [bg=color]
Flags:
  -o Overlay (non-null values only)
  -i Invert catlist
  -x Don't add to list of rasters and commands in monitor
Parameters:
      map Raster map to be displayed
  catlist List of categories to be displayed (INT maps)
  vallist List of values to be displayed (FP maps)
       bg Background color (for null)
            options:
white,black,red,green,blue,yellow,magenta,cyan,aqua,
                     grey,gray,orange,brown,purple,violet,indigo
[0201]
.....(continuing)
I use grass6.2.2 working on FedoraCore5.
I hope someone gives me an advice.
d.mon x0
[0101]
Yes, that is a known mistake which slipped into GRASS 6.2.2, and has been fixed
for the upcoming 6.2.3 release. see-
  http://grass.gdf-hannover.de/wiki/GRASS_6.2_Feature_Plan#6.2.3RC1
(--quiet is only implemented in the development version of GRASS, not 6.2.x)
d.slide.show is just a text file shell script, so you can edit the file by hand
to remove the two "--quiet"s, then it works. (they are near the end of the
file)
Typing "which d.slide.show" at a terminal prompt will tell you the file you
have to edit. (probably as root)
Hamish
      ____________________________________________________________________________________
Get easy, one-click access to your favorites.
Make Yahoo! your homepage.
http://www.yahoo.com/r/hs
