[GRASS-user] error in g.extension while installing i.fusion.hpf in windows
Hello list,
A student is getting the following error when trying to install i.fusion.hpf
C:>g.extension extension=i.fusion.hpf
Downloading precompiled GRASS Addons <i.fusion.hpf>…
Fetching <i.fusion.hpf> from
<http://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.5/i.fusion.hpf.zip>
(be patient)…
File “C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py”, line 2350, in
sys.exit(main())
File “C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py”, line 2330, in main
install_extension(source=source, url=url, xmlurl=xmlurl, branch=branch)
File “C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py”, line 871, in install_extension
ret1, new_modules_ext, new_files_ext = install_extension_win(extension)
File “C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py”, line 1259, in install_extension_win
for line in file:
File “C:\OSGEO4~1\apps\Python37\lib\fileinput.py”, line 252, in next
line = self._readline()
File “C:\OSGEO4~1\apps\Python37\lib\fileinput.py”, line 366, in _readline
return self._readline()
File “C:\OSGEO4~1\apps\Python37\lib\encodings\cp1252.py”, line 23, in decode
return codecs.charmap_decode(input,self.errors,decoding_table)[0]
UnicodeDecodeError: ‘charmap’ codec can’t decode byte 0x9d in position 401: character maps to
Here his settings:
Versión de GRASS: 7.8.5
Code revision: 2b6ab2893
Fecha de compilación: 2020-12-21
Construir plataforma: x86_64-w64-mingw32
GDAL: 3.1.4
PROJ: 6.3.2
GEOS: 3.8.1
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
Plataforma: Windows-10-10.0.19041-SP0 (OSGeo4W)
Any ideas?? He can install other extensions without problems.
Thanks in advance
Vero
On Thu, Mar 18, 2021 at 1:35 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Hello list,
C:\>g.extension extension=i.fusion.hpf
Downloading precompiled GRASS Addons <i.fusion.hpf>...
<http://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.5/i.fusion.hpf.zip&gt;
(be patient)...
  File "C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py", line 2350, in <module>
    sys.exit(main())
  File "C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py", line 2330, in main
  File "C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py", line 871, in install_extension
  File "C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py", line 1259, in install_extension_win
    for line in file:
  File "C:\OSGEO4~1\apps\Python37\lib\fileinput.py", line 252, in __next__
  File "C:\OSGEO4~1\apps\Python37\lib\fileinput.py", line 366, in _readline
  File "C:\OSGEO4~1\apps\Python37\lib\encodings\cp1252.py", line 23, in decode
UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d in position 401: character maps to <undefined>
What surprises me a bit:
file *
constants.py: Python script, UTF-8 Unicode text executable
high_pass_filter.py: Python script, ASCII text executable
i.fusion.hpf.html: HTML document, ASCII text
i_fusion_hpf_lsat7_hpf_rgb.png: PNG image data, 1327 x 840,
8-bit/color RGB, non-interlaced
i_fusion_hpf_lsat7_orig_rgb.png: PNG image data, 1327 x 840,
i.fusion.hpf.py: Python script, ASCII text executable
licenses: directory
Makefile: ASCII text
README.md: UTF-8 Unicode text
test_high_pass_filter.py: Python script, ASCII text executable
--> some .py files are UTF-8, some are not.... shall this be streamlined?
PS: perhaps more a question for grass-dev
Vero,
I’ll try to have a quick look on that during the WE (work overloaded here).
Hopefully it’s something trivial, like this suggestion:
https://stackoverflow.com/a/60197939/1172302
Nikos
On 2021-03-18 13:35, Veronica Andreo wrote:
Hello list,
(be patient)…
sys.exit(main())
for line in file:
Here his settings:
GDAL: 3.1.4
PROJ: 6.3.2
GEOS: 3.8.1
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
Thanks in advance
Vero
I’d really appreciate Nikos! :slight_smile:
El vie, 19 mar 2021 a las 8:28, <nik@nikosalexandris.net> escribió:
Vero,
Nikos
Hello list,
(be patient)…
sys.exit(main())
for line in file:
Here his settings:
GDAL: 3.1.4
PROJ: 6.3.2
GEOS: 3.8.1
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
Thanks in advance
Vero
Can you try this branch https://gitlab.com/NikosAlexandris/i.fusion.hpf/-/tree/encoding
(commit:https://gitlab.com/NikosAlexandris/i.fusion.hpf/-/commit/86c2ae92f158c09947ae366bf20dbf3794b8f191)
Vero,
Nikos
Hello list,
(be patient)…
sys.exit(main())
for line in file:
Here his settings:
GDAL: 3.1.4
PROJ: 6.3.2
GEOS: 3.8.1
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
Thanks in advance
Vero
Hi Nikos
I can try it because I’m using Linux, but installing branches or installing add-ons from urls is not supported for windows, and the error comes when students using windows try to install the add-on (not in linux). So even if I try the gitlab branch here, I cannot tell if all will be fine in windows then…
Vero
Vero,
Nikos
Hello list,
(be patient)…
sys.exit(main())
for line in file:
Here his settings:
GDAL: 3.1.4
PROJ: 6.3.2
GEOS: 3.8.1
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
Thanks in advance
Vero
I know well the issue(s). I don’t run a WinBox currently.
It should suffice to copy the source code in the correct sub-folders.
Which I memorised times ago while working in r.estimap.recreation.
N
On 2021-03-19 13:09, Veronica Andreo wrote:
Hi Nikos
Vero
Vero,
Nikos
Hello list,
(be patient)…
sys.exit(main())
for line in file:
Here his settings:
GDAL: 3.1.4
PROJ: 6.3.2
GEOS: 3.8.1
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
Thanks in advance
Vero
Sorry, too fast. …which sub-folders I don’t recall anymore.
N
