that's the reason of g.extension failing
downloading the zip-file (see link above) and copying the files into the corresponding folders in
C:\Users\YourUserName\AppData\Roaming\GRASS7\addons\
should help.
now tested in this way:
g.region -p -a raster=lsat7_2002_80@PERMANENT align=lsat7_2002_80@PERMANENT
i.fusion.hpf pan=lsat7_2002_80@PERMANENT msx=lsat7_2002_10@PERMANENT,lsat7_2002_20@PERMANENT,lsat7_2002_30@PERMANENT,lsat7_2002_40@PERMANENT suffix=_hpf
|! Region's resolution matched to Pan's (14.25)
Processing image: lsat7_2002_10@PERMANENT
|1 Determining ratio of low to high resolution
Retrieving image resolutions
Resolution ratio low (28.500) to high (14.250): 2.0
|2 High Pass Filtering the Panchromatic Image
|3 Upsampling (bilinearly) low resolution image
|4 Weighting the High-Pass-Filtered image (HPFi)
Weighting = StdDev(MSx) / StdDev(HPFi) * Modulating Factor
StdDev of <lsat7_2002_10@PERMANENT>: 20.702
StdDev of HPFi: 257.949
Modulating Factor: 0.25
|5 Adding weighted HPFi to upsampled image
|+ Quantile scaling of Pansharpened image to lsat7_2002_10@PERMANENT
Processing image: lsat7_2002_20@PERMANENT
StdDev of <lsat7_2002_20@PERMANENT>: 23.325
|+ Quantile scaling of Pansharpened image to lsat7_2002_20@PERMANENT
Processing image: lsat7_2002_30@PERMANENT
StdDev of <lsat7_2002_30@PERMANENT>: 34.711
|+ Quantile scaling of Pansharpened image to lsat7_2002_30@PERMANENT
Processing image: lsat7_2002_40@PERMANENT
StdDev of <lsat7_2002_40@PERMANENT>: 20.479
|+ Quantile scaling of Pansharpened image to lsat7_2002_40@PERMANENT
|! Original Region restored
Hint, rebalancing colors (via i.colors.enhance) may improve appearance of RGB composites!
WARNING: No data base element files found
(Fri Mar 19 21:27:40 2021) Befehl ausgeführt (15 Sek)
the script itself (downloaded from https://wingrass.fsv.cvut.cz/grass78/x86_64/addons/latest/) works.
now we have to solve the g.extension issue.
kind regards
helli
