[GRASS-user] error in g.proj on Windows 10 via R (rgrass7) in GRASS 7.8
The problem occurs using GRASS 7.8 but NOT using 7.6. Likewise, there is
no problem under Linux, only Windows 10.
It might be related to some Windows environmental variables, but I don't
have a clue which ones. As the older version works, I wonder if it is
due to any changes from GRASS 7.6 to 7.8. Could anybody give me a hint?
QGIS bundled GRASS here:
GRASS Version: 7.8.5
Code revision: 2b6ab2893
Build date: 2020-12-21
Build platform: x86_64-w64-mingw32
GDAL: 3.1.4
PROJ: 6.3.2
see https://github.com/rsbivand/rgrass7/issues/27
it may be a mismatch between the GRASS bundled proj version and the R spatial packages bundled proj version.
please check the proj version in GRASS and R.
kind regards
Helmut
