[GRASS-user] error in grass 7.0 configure file
Hi
There is a problem with grass configure sript:
checking whether to use Motif... yes
checking for location of Motif includes...
checking for Xm/Xm.h... no
configure: error: *** Unable to locate Motif includes
while
Xm.h is located in /usr/include/Xm
and --with-motif-includes is added to ./configure command
what is wrong??
in earlier compilation (few weeks ago) --with-motif-includes wasn't necesarry
Jarek
Jarekj:
while
what is wrong??
check what failed at the end of config.log
Hamish
Note that Motif is only used by xganim.
while
From that compiler's perspective, it's more accurate to say that
<Xm/Xm.h> is located in /usr/include.
what is wrong??
You shouldn't be specifying --with-motif-includes= if <Xm/Xm.h> is in
/usr/include (as above).
necesarry
It still shouldn't be necessary.
Look in config.log for the actual error message.
Thanks for hint.
In file included from configure:13431:
/usr/include/Xm/Xm.h:59:34: error: X11/extensions/Print.h: No such file or directory
configure: failed program was:
but print.h also exist in /usr/include/X11/extension
but its seems looks like my linux problem
thanks again
Jarek
Hamish pisze:
Jarekj:
while
what is wrong??
Hamish
or directory
print.h or Print.h? Case matters. It should be Print.h, with a capital
"P".
FWIW, the file is part of the XPrint extension (the relevant package
is usually named "printproto").
Glynn Clements pisze:
Of course Print.h, type mismatch :wink:
"P".
well, I have both printproto and printporto-dev installed and from april 08 (Hardy Heron) i compile grass70 regularly and nothing happens so I'm little surprised...
very thinks for your suggestions
Jarek
