Hi
I’m using GRASS6.4.svn from latest week snapshot in Ubuntu and I was testing a few functions while I got an error when creating a image group with NorthCarolina Dataset.
I did:
i.group group=gr04 subgroup=sub input=lsat7_2000_10@landsat,lsat7_2000_20@landsat,lsat7_2000_30@landsat,lsat7_2000_40@landsat,lsat7_2000_50@landsat,lsat7_2000_70@landsat
And I got:
Adding raster map lsat7_2000_10@landsat to group
Adding raster map lsat7_2000_20@landsat to group
Adding raster map lsat7_2000_30@landsat to group
Adding raster map lsat7_2000_40@landsat to group
Adding raster map lsat7_2000_50@landsat to group
Adding raster map lsat7_2000_70@landsat to group
Adding raster map lsat7_2000_10@landsat to subgroup
Adding raster map lsat7_2000_20@landsat to subgroup
Adding raster map lsat7_2000_30@landsat to subgroup
Adding raster map lsat7_2000_40@landsat to subgroup
Adding raster map lsat7_2000_50@landsat to subgroup
Adding raster map lsat7_2000_70@landsat to subgroup
Then when I open i.cluster GUI I selected gr04 group and, sub doesn’t appear in subgroup. It only appears “Not a selectable element”. If I leave it blank it doesn’t run (sub group is a required option). But, if I write “sub” it works…
Is this suppose to happen?
Nikos
On Wed, Apr 14, 2010 at 7:05 PM, Nikos Dumakis <nikosdu1980@gmail.com> wrote:
Hi
I'm using GRASS6.4.svn from latest week snapshot in Ubuntu and I was testing
I did:
And I got:
Adding raster map <lsat7_2000_10@landsat> to group
Adding raster map <lsat7_2000_20@landsat> to group
Adding raster map <lsat7_2000_30@landsat> to group
Adding raster map <lsat7_2000_40@landsat> to group
Adding raster map <lsat7_2000_50@landsat> to group
Adding raster map <lsat7_2000_70@landsat> to group
Adding raster map <lsat7_2000_10@landsat> to subgroup
Adding raster map <lsat7_2000_20@landsat> to subgroup
Adding raster map <lsat7_2000_30@landsat> to subgroup
Adding raster map <lsat7_2000_40@landsat> to subgroup
Adding raster map <lsat7_2000_50@landsat> to subgroup
Adding raster map <lsat7_2000_70@landsat> to subgroup
Then when I open i.cluster GUI I selected gr04 group and, sub doesn't appear
in subgroup. It only appears "Not a selectable element". If I leave it blank
it doesn't run (sub group is a required option). But, if I write "sub" it
works...
I would say no. It reminds me of
http://trac.osgeo.org/grass/ticket/780
Does anyone reports the same? because that happened with Win32 and I’m using a snapshot from 10/4/2010 in Ubuntu9.10.
It happens the same in i.cluster and in all the others menus that required groups…
Hi
I did:
And I got:
works…
I get exacly the same thing. In sub-group list nothing appears. I’m using WinGRASS6.4RC5 and GRASS6.5 and GRASS6.4 from last week on Ubuntu…
Should it be reported as a bug?
On Wed, Apr 14, 2010 at 10:32 PM, Nikos Dumakis <nikosdu1980@gmail.com> wrote:
Hi
I did:
And I got:
works…
grass-user mailing list
grass-user@lists.osgeo.org
