Greetings
I have been testing i.maxlik and I’m getting a strange error. When I select the group, in group parameter, automatically, sub-group list includes the available sub-groups but, when i select one, it’s selected in the frame but it’s not inserted in the command to be runned. In the bottom it’s still . I can only run i.maxlik by inserting directly the parameters in the commandline-output.
Has anyone having the same problem?
Thanks
Jenny
2010/6/24 Jenny Turner <jennyturner1980@gmail.com>:
I have been testing i.maxlik and I'm getting a strange error. When I select
available sub-groups but, when i select one, it's selected in the frame but
it's not inserted in the command to be runned. In the bottom it's still
<REQUIRED>. I can only run i.maxlik by inserting directly the parameters in
GRASS version?
OS?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Hello Martin
I got this error in GRASS6.4.0.RC6, from two weeks ago in LinuxUbuntu9.10 but also in Windows.
Jenny
On Fri, Jun 25, 2010 at 9:57 PM, Martin Landa <landa.martin@gmail.com> wrote:
GRASS version?
OS?
Martin
Hi again
This error not only occurs in i.maxlik but also in the others modules where users should select sub-group (except georrectify GU).
Dones anyone has the same problem?
Thanks
Jenny
On Mon, Jun 28, 2010 at 9:51 AM, Jenny Turner <jennyturner1980@gmail.com> wrote:
Hello Martin
Jenny
GRASS version?
OS?
Martin
could it be related to
http://trac.osgeo.org/grass/ticket/780
On Tue, Jun 29, 2010 at 10:07 AM, Jenny Turner
Hi again
Thanks
Jenny
wrote:
Hello Martin
Jenny
wrote:
> select
> the
> but
> parameters in
GRASS version?
OS?
Martin
grass-user mailing list
grass-user@lists.osgeo.org
Hi
It might be something to do with that. But for instance, I have used GRASS6.4.RC5 from Jan/Feb and it was ok regarding this issue. and now it’s not. Or am I doing sometyhing wrong?
On Tue, Jun 29, 2010 at 12:42 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi again
Thanks
Jenny
wrote:
Hello Martin
Jenny
wrote:
select
the
but
parameters in
GRASS version?
OS?
Martin
This is a follow-up of a message that I sent last week.
I have compiled last weekly snapshot and the problem maintains. in functions just like i.maxlik I can select subgroup but it’s not inserted in the command So all functions that requires sub-groups cannot be runned from graphic-interfaces.
As well as I tried to add images to a group/sub-group and I cannot open the dropdown box for image selection in i.group. Shall I add this to the Trac list?
On Wed, Jun 30, 2010 at 3:35 PM, Jenny Turner <jennyturner1980@gmail.com> wrote:
Hi
Hi again
Thanks
Jenny
wrote:
Hello Martin
Jenny
wrote:
select
the
but
parameters in
GRASS version?
OS?
Martin
