Hello,
I’m preparing a workshop for geostat and I want to use r.bioclim. Data was converted to degree C. This is the command i use:
r.bioclim
tmin=g.list type=raster pattern="lst_minimum_??" separator=,
tmax=g.list type=raster pattern="lst_maximum_??" separator=,
tavg=g.list type=raster pattern="lst_average_??" separator=,
output=lst_
toutscale=1
However, I get the following error, when the process reaches bio11 and bio11:
Mean temperature for each quarter year …
BIO10 = Mean Temperature of Warmest Quarter,
BIO11 = Mean Temperature of Coldest Quarter …
ERROR: Raster map not found
File “/home/veroandreo/.grass7/addons/scripts/r.bioclim”, line 618, in
main()
File “/home/veroandreo/.grass7/addons/scripts/r.bioclim”, line 316, in main
method = ‘maximum,minimum’)
File “/home/veroandreo/software/grass77-dev/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py”, line 441, in run_command
return handle_errors(returncode, returncode, args, kwargs)
File “/home/veroandreo/software/grass77-dev/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py”, line 343, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None r.series input= output=lst_bio10.18931,lst_bio11.18931 method=maximum,minimum ended with error
Process ended with non-zero return code 1. See errors in the (error) output.
The input maps are there (12 Tmin, 12 Tmax and 12 Tavg), which is the map it does not find then? Where do I find this (error) output??
Thanks in advance for any help
Vero
On Wed, Aug 14, 2019 at 8:32 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Hello,
r.bioclim
output=lst_
toutscale=1
main()
this error was introduced by Markus N with
https://github.com/OSGeo/grass-addons/commit/7eb1fc10fcc7e56e93444a37287602ff41ec6a15#diff-53570b3d7e95af6c262896a8d57e367e
fixed in 7433d29b
Markus M
Vero
grass-user mailing list
grass-user@lists.osgeo.org
On Thu, Aug 15, 2019 at 9:48 AM Markus Metz <markus.metz.giswork@gmail.com> wrote:
Hello,
r.bioclim
output=lst_
toutscale=1
main()
fixed in 7433d29b
another bug introduced with the same previous commit 7eb1fc1 fixed in 8858cf2b
Markus M
Vero
Cool
But tabs/spaces should definitely not mixed. Please check your editor settings.
markusN
Thanks much Markus and Markus!!!
All working good now
Vero
El jue., 15 ago. 2019 a las 10:50, Markus Neteler (<neteler@osgeo.org>) escribió:
Cool
markusN
