I have a strange error when I’m try to remove the mask
GRASS 7.0.2 (loc_river_fill_GLOBE):~ > r.mask -r
File “/gpfs/apps/hpc.rhel7/Apps/GRASS/7.0.2/grass-7.0.2/scripts/r.mask”, line 184, in
main()
File “/gpfs/apps/hpc.rhel7/Apps/GRASS/7.0.2/grass-7.0.2/scripts/r.mask”, line 104, in main
type = ‘raster’, name = ‘MASK’)
File “/gpfs/apps/hpc.rhel7/Apps/GRASS/7.0.2/grass-7.0.2/etc/python/grass/script/core.py”, line 394, in run_command
return handle_errors(returncode, returncode, args, kwargs)
File “/gpfs/apps/hpc.rhel7/Apps/GRASS/7.0.2/grass-7.0.2/etc/python/grass/script/core.py”, line 312, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None [‘g.remove’, ‘–q’, ‘-f’, ‘type=raster’, ‘name=MASK’] ended with error
Process ended with non-zero return code -11. See errors in the (error) output.
[Raster MASK present]
even if i try to remove
the MASK directly
g.remove -f type=raster name=MASK
or the file associate to it
g.remove -f type=raster name=UNIT3753
I get Segmentation fault
I try also to r.in.gdal the file again, the file is imported successfully, but I still not able to remove the MASK.
In the past I have used the UNIT3753-raster several time without problem than one week ago I used to create another data set
r.patch input=“UNIT3753,UNIT4000” output=“UNIT3753_4000”
Could be that the UNIT3753 raster is “link” to the UNIT3753_4000 and lock any kind of operation associate to it?
Thanks
Giuseppe
Giuseppe Amatulli, Ph.D.
Research scientist at
Yale School of Forestry & Environmental Studies
Yale Center for Research Computing
Center for Science and Social Science Information
New Haven, 06511
Teaching: http://spatial-ecology.org
Work: https://environment.yale.edu/profile/giuseppe-amatulli/
