[GRASS-user] Error in sqlite3_step()
I am receiving the following error when patching two point vector maps:
v.patch -e in=SBC1,SBC2 out=SBC_0607
Patching vector map <SBC1@craig>...
DBMI-SQLite driver error:
Error in sqlite3_step():
SQL logic error or missing database
ERROR: Cannot insert new record: 'insert into SBC_0607 values ( 64510,
       'Dwelling', 'The Msunduzi', 37)'
The attribute tables look like this :
v.info -c SBC1
Displaying column types/names for database connection of layer 1:
INTEGER|cat
CHARACTER|CLASS_NAME
CHARACTER|LM
INTEGER|WARD
v.info -c SBC2
INTEGER|cat
CHARACTER|LM
INTEGER|WARD
I have checked disk space and file size of the sqlite db - no problems
there. Any ideas why sqlite chokes on cat 64510?
sqlite 3.4.2
grass 6.5
ubuntu 7.10
Craig
v.info -c SBC1
INTEGER|cat
CHARACTER|LM
INTEGER|WARD
v.info -c SBC2
INTEGER|cat
CHARACTER|LM
INTEGER|WARD
What does v.db.connect -p show for each of the two maps ?
Moritz
v.db.connect -p map=SBC1
Vector map <SBC1@craig> is connected by:
layer <1> table <SBC1> in database
</home/craig/GIS/grassdata/uMDM_ll/craig/sqlite.db> through driver
<sqlite> with key <cat>
v.db.connect -p map=SBC2
Vector map <SBC2@craig> is connected by:
layer <1> table <SBC2> in database
All looks fine to me. BTW v.patch works if I drop the -e option, but I
need the attributes.
Craig
And what about v.info -c / v.db.connect -p SBC_0607 ?
db.connect -p ?
Also what do you see when you run
sqlite3 /home/craig/GIS/grassdata/uMDM_ll/craig/sqlite.db
And then .tables and/or .schema TableName at the command prompt ?
Maybe you can also set
g.gisenv set=DEBUG=3
and see if you get any useful debug info.
Moritz
Moritz,
Thanks for the suggestions. I think I've got something:
Notice that the second and third columns contain strings.
db.describe -c table=SBC1 driver=sqlite
database=/home/craig/GIS/grassdata/uMDM_ll/craig/sqlite.db
ncols: 4
nrows: 197842
Column 1: cat:INTEGER:20
Column 2: CLASS_NAME:CHARACTER:1
Column 3: LM:CHARACTER:1
Column 4: WARD:INTEGER:20
Second and third columns are type CHARACTER with length=1 ???
How did this happen, as SBC1 was generated by:
g.copy v=SBC_0506,SBC1
and then modified with a few runs of v.db.dropcol map=SBC1 layer=1 col=
Columns CLASS_NAME and LM are correctly specified in the original
vector (SBC_0506):
db.describe -c table=SBC_0506 driver=sqlite
ncols: 21
nrows: 197842
Column 2: CLASS:DOUBLE PRECISION:20
Column 3: CLASS_NAME:CHARACTER:20
Column 4: SOURCE:CHARACTER:15
Column 5: PROV:CHARACTER:25
Column 6: MUNIC:CHARACTER:50
Column 7: ESKOM_FSA:CHARACTER:25
Column 8: TRIBAL_AUT:CHARACTER:50
Column 9: PROCLAIMED:CHARACTER:5
Column 10: INT_ERVEN:CHARACTER:5
Column 11: INT_FARM:CHARACTER:5
Column 12: INT_FARMPN:CHARACTER:5
Column 13: INT_AGRHLD:CHARACTER:5
Column 14: INT_PARK:CHARACTER:5
Column 15: INT_TA:CHARACTER:5
Column 16: SUB_HV_DES:CHARACTER:25
Column 17: SUB_MV_DES:CHARACTER:25
Column 18: TRNSFMR_NM:CHARACTER:25
Column 19: SOURCE_IMG:CHARACTER:20
Column 20: LM:CHARACTER:20
Column 21: WARD:INTEGER:20
It seems to me that either g.copy or v.db.dropcol has messed up
columns 3 and 20 (in the original vector). Can I change the length of
columns 2 and 3 in SBC1 and SBC2 or maybe I can copy the columns to
new columns with the correct length?
Thanks
Craig
On 03/04/09 10:03, Craig Leat wrote:
Moritz,
ncols: 4
nrows: 197842
vector (SBC_0506):
ncols: 21
nrows: 197842
If you can reproduce this, especially with the GRASS demo data, then please file a bug report.
AFAIK, sqlite does not support alter column statements, but I think you can change column types in sqlitebrowser (don't know how they implement this). But you can obviously do it via copying.
SQLite does not really enforce column types (unless you tell it explicitely to do so), so normally you can put whatever you want into whatever column. This does sometimes create problems with GRASS' internal SQL type checks.
Moritz
On Fri, Apr 3, 2009 at 10:59 AM, Moritz Lennert
Right:http://www.sqlite.org/omitted.html
See the script v.db.renamecol
-> # some tricks
how to potentially work around (create new column, transfer content).
I have a problem with v.db.dropcol, it's changing the length of columns.
ncols: 6
nrows: 197842
Column 5: building:CHARACTER:20
Column 6: LM_name:CHARACTER:20
v.db.dropcol map=SBC1 col=CLASS_NAME
ncols: 5
nrows: 197842
Column 2: LM:CHARACTER:1
Column 3: WARD:INTEGER:20
Column 4: building:CHARACTER:1
Column 5: LM_name:CHARACTER:1
building and LM_name have changed from length=20 to length=1
I'll test with Spearfish and update GRASS before reporting a bug, but
this may take some time. First I have to finish this job with a broken
v.db.dropcol. It's time to play with sqlitebrowser...
Craig
ncols: 6
nrows: 197842
ncols: 5
nrows: 197842
Don't have time to look into this now, but it must be a problem in the special sqlite implementation in that script:
if [ "$driver" = "sqlite" ] ; then
         #echo "Using special trick for SQLite"
         # http://www.sqlite.org/faq.html#q13
         v.info --q -c map=$GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d'|' -f1,2 | grep -v "|${col}$" > "$TMP.coldesc"
         # need to revert order:
         cat "$TMP.coldesc" | cut -d'|' -f1 > "$TMP.coltypes"
         cat "$TMP.coldesc" | cut -d'|' -f2 > "$TMP.colnames"
         COLDEF=`paste -d' ' "$TMP.colnames" "$TMP.coltypes" | tr '\n' ',' | sed 's+,$++g'`
         COLNAMES=`cat "$TMP.colnames" | tr '\n' ',' | sed 's+,$++g'`
echo "BEGIN TRANSACTION;
CREATE TEMPORARY TABLE ${table}_backup(${COLDEF});
INSERT INTO ${table}_backup SELECT ${COLNAMES} FROM ${table};
DROP TABLE ${table};
CREATE TABLE ${table}(${COLDEF});
INSERT INTO ${table} SELECT ${COLNAMES} FROM ${table}_backup;
DROP TABLE ${table}_backup;
COMMIT;" > "$TMP"
db.execute input="$TMP"
You could try the individual steps and see where the problem comes from.
You can also try this:
https://addons.mozilla.org/en-US/firefox/addon/5817
Moritz
sed 's+,$++g'`
COMMIT;" > "$TMP"
My execute statement looks like this:
BEGIN TRANSACTION;
CREATE TEMPORARY TABLE SBC2_backup(cat INTEGER,LM CHARACTER,WARD
INTEGER,CLASS_NAME CHARACTER);
INSERT INTO SBC2_backup SELECT cat,LM,WARD,CLASS_NAME FROM SBC2;
DROP TABLE SBC2;
CREATE TABLE SBC2(cat INTEGER,LM CHARACTER,WARD INTEGER,CLASS_NAME CHARACTER);
INSERT INTO SBC2 SELECT cat,LM,WARD,CLASS_NAME FROM SBC2_backup;
DROP TABLE SBC2_backup;
COMMIT;
Why does v.db.dropcol define a type CHARACTER when sqlite3 supports
(NULL, INTEGER, REAL, TEXT, BLOB)?
Craig
sed 's+,$++g'`
COMMIT;" > "$TMP"
BEGIN TRANSACTION;
DROP TABLE SBC2;
COMMIT;
v.db.dropcol just uses the output of v.info -c, and AFAIR, SBC2 has its columns defined as CHARACTER, or ?
Moritz
sed 's+,$++g'`
COMMIT;" > "$TMP"
BEGIN TRANSACTION;
DROP TABLE SBC2;
COMMIT;
See also this thread:
http://lists.osgeo.org/pipermail/grass-user/2009-January/048281.html
Moritz
Yeah. I have recently noticed this type of behavior after switching to
sqlite. I was unable to patch two vectors (and att tables) after
defining new columns of type varchar(20). I re-made the columns as
'text' and v.patch worked as expected. Maybe we need some special,
internal conversions (varchar ---> text) when working with sqlite db.
Dylan
On Mon, Apr 6, 2009 at 2:58 AM, Moritz Lennert
-f1,2
sed 's+,$++g'`
COMMIT;" > "$TMP"
BEGIN TRANSACTION;
DROP TABLE SBC2;
CHARACTER);
COMMIT;
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
Dylan:
v.info -c SBC2
INTEGER|cat
INTEGER|WARD
TEXT|LM
TEXT|CLASS_NAME
db.describe -c table=SBC2 driver=sqlite
ncols: 4
nrows: 7961
Column 2: WARD:INTEGER:20
Column 3: LM:TEXT:1000
Column 4: CLASS_NAME:TEXT:1000
v.info -c SBC1
INTEGER|cat
INTEGER|WARD
TEXT|LM
TEXT|CLASS_NAME
ncols: 4
nrows: 197842
Ps. I didn't specify the lengths of columns 3 and 4. 1000 must be the
default length for text.
v.patch -e in=SBC1,SBC2 out=SBC_test
ERROR: Cannot insert new record: 'insert into SBC_test values ( 64510, 37,
       'The Msunduzi', 'Dwelling')'
So GRASS (6.5 r35892) rejects both CHARACTER:1 (see earlier in the
thread) and TEXT:1000.
Let's try with debugging on:
v.patch -e in=SBC1,SBC2 out=SBC_test2
D3/3: fetch row = 64506
D3/3: col 0, litetype 1, sqltype 3: val = '64508'
D3/3: col 1, litetype 1, sqltype 3: val = '3'
D3/3: col 2, litetype 3, sqltype 13: val = 'Mkhambathini'
D3/3: col 3, litetype 3, sqltype 13: val = 'Dwelling'
D3/3: Row fetched
D2/3: SQL: insert into SBC_test2 values ( 64509, 3, 'Mkhambathini', 'Dwelling')
D3/3: execute: insert into SBC_test2 values ( 64509, 3,
D3/3: fetch row = 64507
D3/3: col 0, litetype 1, sqltype 3: val = '64509'
D3/3: col 1, litetype 1, sqltype 3: val = '37'
D3/3: col 2, litetype 3, sqltype 13: val = 'The Msunduzi'
D3/3: Row fetched
D2/3: SQL: insert into SBC_test2 values ( 64510, 37, 'The Msunduzi', 'Dwelling')
D3/3: execute: insert into SBC_test2 values ( 64510, 37, 'The
D2/3: G__home home = /home/craig
ERROR: Cannot insert new record: 'insert into SBC_test2 values ( 64510, 37,
Might the space in 'The Msunduzi' cause the problem?
db.describe -c table=test driver=sqlite
ncols: 4
nrows: 7963
echo "INSERT INTO test (cat,WARD,LM,CLASS_NAME) values (8000,1,'test
phrase','test')" | db.execute
v.db.select test | tail
7953|26|The Msunduzi|Dwelling
7954|19|The Msunduzi|Dwelling
7955|1|Mpofana|Dwelling
7956|1|Mpofana|Dwelling
7957|1|Mpofana|Dwelling
7958|1|Mpofana|Dwelling
7959|1|Mpofana|Dwelling
7960|1|Mpofana|Dwelling
7961|1|Mpofana|Dwelling
8000|1|test phrase|test
So the above db.execute command worked. This also works:
echo "insert into test values ( 8002, 37, 'The Msunduzi', 'Dwelling')"
| db.execute
BTW the same error message is given if I try to insert into a cat
that's already used. I checked SBC1 around cat 64510 and didn't see
any duplicate cats.
Any more ideas from anyone?
Craig
Count another error here:
"Error in sqlite3_step():
database is locked"
All I am trying to do is:
v.what.rast vector=points raster=FINAL column=test
Nikos
database is locked"
WoW :open_mouth:
All of a sudden, I can't copy vector maps, drop or add columns anymore.
I checked dbase connections and all looks fine. The problem started
after trying to use v.what.rast and then sqlitebrowser to remove some
column.
Could it be a sqlitebrowser side-effect?
Thanks, Nikos
On Mon, May 4, 2009 at 3:20 PM, Nikos Alexandris
database is locked"
WoW :open_mouth:
column.
Perhaps... I found
http://www.sqlite.org/lockingv3.html
With "lsof" you can find out who's using a file or a process.
database is locked"
WoW :open_mouth:
column.
IIRC, if you use sqlitebrowser, you need to save your changes, before being able to access the db from GRASS.
BTW, has anyone compared sqlitebrowser to the sqlite manager add-on to firefox [1,2] ? After very rough first trials I have the feeling that the latter actually has a nicer feel to it, but need to do more testing...
Moritz
[1] https://addons.mozilla.org/fr/firefox/addon/5817
[2] http://code.google.com/p/sqlite-manager/
Moritz:
The fact is that I couldn't do any changes to save them!
Not a real comparison but I tend to agree that it feels "smoother".
Nikos
