Hello,
I trying to generate a 3d DEM of a gully headcut. The point data was gained by terrestrial laser scanner.
As I am doing my first attempts, I do not change any parameters from that given by default.
This is the result:
v.vol.rst input=BAR1_SCAN_UTM@Georef41 wcolumn=dbl_3 tension=40. smooth=0.1 segmax=50 npmin=200 dmin=0.050026 wmult=1.0 zmult=1.0 elev=Olite_3d --overwrite
1511728 records selected from table
some points outside of region -- will ignore...
strip exists with insufficient data
Processing all selected output files will require 1435616 bytes of disk space for temp files
There are points outside specified 2D/3D region--ignored 57754 points (total points: 1511728)
Points are more dense than specified 'DMIN'--ignored 1131669 points (remain 380059)
Percent complete:
Error in COGRR!
Interp_call failed!
Can someone give me an idea if this is my fault?
Thank you!
Manuel
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www-neu.uni-trier.de/index.php?id=9607
what is the form of the raw data? x,y,z point cloud?
is there only one x,y for each z, or are there overhangs?
I ask because if there is only one z for each x,y then perhaps a 2.5D surface is more appropriate and the processing is much simpler:
http://grass.osgeo.org/wiki/Help_with_3D#Raster_2.5D_Surfaces
that may obscure fine details of steep slopes though, lumping them all into one horizontal cell. Maybe the cell resolution would have to be very small.
If that isn't good enough an idea, if you don't mind it, is to switch the z coordinate with x or y when you import and then look at the thing side on.
This is the result:
(remain 380059)
Percent complete:
Error in COGRR!
Interp_call failed!
No idea about that.
Hamish
Hello Markus, hello Hamish, and List!
I imported a transformed shapefile.
g.region -p gives:
projection: 1 (UTM)
zone: 30
datum: wgs84
ellipsoid: wgs84
north: 4681874.175
south: 4681826.55
west: 624764.175
east: 624839.625
nsres: 0.075
ewres: 0.075
rows: 635
cols: 1006
cells: 638810
as it is a gully headcut, I have steep slopes (vertical!) and overhangs and some shadowing...
Thanks again!
Manuel
This is the result:
Percent complete:
Error in COGRR!
Interp_call failed!
No idea about that.
Hamish
Dr. Manuel Seeger
D - 54286 Trier
Hallo Frühaufsteher!
Here is the output of gregion -p3
projection: 1 (UTM)
zone: 30
datum: wgs84
ellipsoid: wgs84
north: 4681874.175
south: 4681826.55
west: 624764.175
east: 624839.625
top: 343.00000000
bottom: 337.00000000
nsres: 0.075
nsres3: 0.10005252
ewres: 0.075
ewres3: 0.10006631
tbres: 0.01
rows: 635
rows3: 476
cols: 1006
cols3: 754
depths: 600
cells: 638810
3dcells: 215342400
Thanks!
Manuel
Markus Neteler schrieb:
Hallo Manuel,
das war g.region -p aber nicht g.region -p3
g.region -p gives:
projection: 1 (UTM)
zone: 30
datum: wgs84
ellipsoid: wgs84
north: 4681874.175
south: 4681826.55
west: 624764.175
east: 624839.625
nsres: 0.075
ewres: 0.075
rows: 635
cols: 1006
cells: 638810
some shadowing...
Thanks again!
Manuel
small.
This is the result:
Percent complete:
Error in COGRR!
Interp_call failed!
No idea about that.
Hamish
Dr. Manuel Seeger
D - 54286 Trier
grass-user mailing list
grass-user@lists.osgeo.org
Dr. Manuel Seeger
D - 54286 Trier
