[GRASS-user] ERROR mapset <mapname> not found
I have a problem with setting the mapset access for one mapset. All other mapsets can be accessed without problems and from different mapsets. I get:
I already checked the folders, but I cannot find any abnormalities.
What could it be?
Thanks in advance for ideas,
Achim
Could this be a permission / ownership problem?
On Tue, Mar 30, 2010 at 5:37 AM, Achim Kisseler
<ak7@jupiter.uni-freiburg.de> wrote:
What could it be?
Achim
grass-user mailing list
grass-user@lists.osgeo.org
Some more details:
I'm using grass65svn, fresh compiled on a kubuntu 64bit.
The mapset I cannot access is one of 7. From the one I can connect to the others, but not the other way around.
Could it be that the mapset is locked? If yes, where can I find out and how can I change that?
The folder has the same permissions as the others.
Achim
On 30.03.2010 10:37, Achim Kisseler wrote:
mapsets. I get:
What could it be?
Achim
Some more details:
A mapset is locked by creating a ".gislock" file in the mapset
directory (note the leading "."). But the error which you report
doesn't sound like a locked mapset.
It would help if you specified the exact command which you run and the
exact error message (copied and pasted, not re-typed) which it
generates.
Are you sure that the directory is actually a mapset, i.e. does it
contain the WIND and VAR files? Do these files have the correct
ownership and permissions?
right, thats not the problem.
generates.
here I use the gui: Config -> GRASS working enviroment -> mapset access
Yes, I'm sure.
>>>>>>>>EDIT>>>>>>>>
Now I used the command line:
g.mapsets addmapset=mapname
and it worked!
But now: the gui doesnt work anymore:
   File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py",
line 257, in OnMapsets
dlg = preferences.MapsetAccess(parent=self, id=wx.ID_ANY)
   File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/pr
eferences.py", line 2137, in __init__
self.mapsetlb.CheckItem(self.all_mapsets.index(mset), True)
ValueError
list.index(x): x not in list
BTW:
g.mapsets -s
shows the tcltc dialog!?
Thats ok for me, because it works, but WHY does this happen?
Thanks everyone very much for the hints,
Achim
