[GRASS-user] error message when launching GRASS GIS 6.4 ORC6 on MacOSX 10.6.5 + how to uninstall - upgrade?
When launching GRASS (installed from
http://www.kyngchaos.com/software/grass) the following error message
appears:
'/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Cube007:~ janvb$ '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
ln: /Users/janvb/Library/Documentation/Help/GRASS-6.4: No such file or directory
Rebuilding Addon menu...
2010-11-28 12:25:14.184 osascript[2420:903] Error loading
/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe
Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit
Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image
found. Did find:
Types.osax/Contents/MacOS/Adobe Unit Types: no matching architecture
in universal wrapper
osascript: OpenScripting.framework - scripting addition
"/Library/ScriptingAdditions/Adobe Unit Types.osax" declares no
loadable handlers.
Python 2.6.1 found.
Cleaning up temporary files ...
Starting GRASS ...
Do I need to do something about this?
Also what could I do (in the future) to upgrade GRASS to a newer
version on Mac? Just uninstall (delete grass) and install the new
version?
Jan
On Nov 28, 2010, at 5:44 AM, Jan Verbesselt wrote:
appears:
The parent folder doesn't for some reason. You can create it in a Terminal:
mkdir -p ~/Library/Documentation/Help
found. Did find:
loadable handlers.
This is normal Adobe nonsense and harmless. It's from an old version of Photoshop that doesn't support 64bit (don't delete it or you won't be able to open files in Photoshop by double-click or drag-n-drop).
version?
Run a new installer. No need to delete first.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
