On Tue, Dec 2, 2014 at 10:49 AM, Markus Neteler <neteler@osgeo.org> wrote:
On Tue, Dec 2, 2014 at 10:39 AM, RichardCooper <richtcooper@hotmail.com> wrote:
I upgraded GDAL to 1.10.0 (via the Ubuntu repository) and the GRASS instance,
but the error still persists.
Could you make the file (offlist) available for testing?
Thanks, got it.
So, it also fails with GDAL 1.10.x but works ok with GDAL 1.11.x:
[neteler@giscluster grumpv1]$ gdal-config --version
1.11.0
[neteler@giscluster grumpv1]$ gdalinfo thauds00g
Driver: AIG/Arc/Info Binary Grid
Files: thauds00g
thauds00g.aux
thauds00g/w001001x.adf
thauds00g/metadata.xml
thauds00g/prj.adf
thauds00g/w001001.adf
thauds00g/log
thauds00g/dblbnd.adf
thauds00g/hdr.adf
thauds00g/sta.adf
Size is 1320, 1920
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4326"]]
Origin = (96.000000000000000,20.999999999936001)
Pixel Size = (0.008333333333300,-0.008333333333300)
Corner Coordinates:
Upper Left ( 96.0000000, 21.0000000) ( 96d 0' 0.00"E, 21d 0' 0.00"N)
Lower Left ( 96.0000000, 5.0000000) ( 96d 0' 0.00"E, 5d 0' 0.00"N)
Upper Right ( 107.0000000, 21.0000000) (107d 0' 0.00"E, 21d 0' 0.00"N)
Lower Right ( 107.0000000, 5.0000000) (107d 0' 0.00"E, 5d 0' 0.00"N)
Center ( 101.5000000, 13.0000000) (101d30' 0.00"E, 13d 0' 0.00"N)
Band 1 Block=256x4 Type=Float32, ColorInterp=Undefined
Description = thauds00g
Min=0.000 Max=32565.402
NoData Value=-3.4028234663852886e+38
Metadata:
LAYER_TYPE=athematic
[neteler@giscluster grumpv1]$ gdalinfo thauds00ag
Files: thauds00ag
thauds00ag.aux
thauds00ag/w001001x.adf
thauds00ag/metadata.xml
thauds00ag/prj.adf
thauds00ag/w001001.adf
thauds00ag/log
thauds00ag/dblbnd.adf
thauds00ag/hdr.adf
thauds00ag/sta.adf
Size is 1320, 1920
GEOGCS["WGS 84",
DATUM["WGS_1984",
Corner Coordinates:
Description = thauds00ag
Min=0.000 Max=32764.812
Metadata:
--> all fine.
In the Fedora/RPM world there is "mock" to easily recompile a newer
package for a local machine.
Something similar will exist for Mint/Ubuntu etc. in order to avoid to
mess around manually with configure options.
hope this helps,
