[GRASS-user] error on startup
After compiling grass 6.2.0beta3 with no apparent errors in make I get the following error at startup, and d.m or gis.m won’t start:
See the licence terms with: g.version -c
If required, restart the graphical user interface with: gis.m &
When ready to quit enter: exit
GRASS 6.2.0beta3 (NZ):~/grass-6.2.0beta3 > Error in startup script: can’t read “monitor_zooms(1,1,n)”: no such variable
while executing
“lappend region $monitor_zooms($mon,1,$attr)”
(procedure “MapCanvas::currentzoom” line 13)
invoked from within
“MapCanvas::currentzoom $mon”
(procedure “MapCanvas::coordconv” line 23)
invoked from within
“MapCanvas::coordconv $mon”
(procedure “MapCanvas::create” line 68)
invoked from within
“MapCanvas::create”
(procedure “Gm::startmon” line 11)
invoked from within
“Gm::startmon”
(procedure “Gm::create” line 69)
invoked from within
“Gm::create”
(procedure “main” line 30)
invoked from within
“main $argc $argv”
(file “/usr/local/grass-6.2.0beta3/etc/gm/gm.tcl” line 522)
Can you help outhere?
thanks,
-Jeroen.
I found the problem, I had an outdated version of gdal, after building a fresh one the build of Grass 6.2.0beta3 worked fine.
sorry to have bothered you,
-Jeroen.
At 15:49 23-9-2006, Jeroen Wortel wrote:
After compiling grass 6.2.0beta3 with no apparent errors in make I get the following error at startup, and d.m or gis.m won't start:
GRASS 6.2.0beta3 (NZ):~/grass-6.2.0beta3 > Error in startup script: can't read "monitor_zooms(1,1,n)": no such variable
    while executing
"lappend region $monitor_zooms($mon,1,$attr)"
    (procedure "MapCanvas::currentzoom" line 13)
    invoked from within
"MapCanvas::currentzoom $mon"
    (procedure "MapCanvas::coordconv" line 23)
    invoked from within
"MapCanvas::coordconv $mon"
    (procedure "MapCanvas::create" line 68)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 69)
    invoked from within
"Gm::create"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.2.0beta3/etc/gm/gm.tcl" line 522)
thanks,
-Jeroen.
grassuser mailing list
grassuser@grass.itc.it
RC(0.3)1r2m B-- C-- D++ F N- S? O! OCGP a29
Is it possible to label 3d vector points with their z values on a normal 2D output in gis.m? There is no database table connected.
thanks,
-Jeroen.
hi,
On Sun, Sep 24, 2006 at 12:33:08PM +0000, Jeroen Wortel wrote:
thanks,
-Jeroen.
what about
v.to.db option=coor
d.vect ...
jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
