[GRASS-user] error running digitzing tool wxpython
Hello Grass Usersgroup
Running on linux open suse 10.3 have download grass-6.4.svn_src_snapshot_2008_11_15.tar.gz
en install some additional libraries (wxwidget, wxpyton ,swig etc) and compiled the source-code include the pyton
digitizing tool v.digit.
Running the digitize tool I've the following error masseges:
if len(self.vdigitMove['id']) > 0:
TypeError
tuple indices must be integers
  File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/ma
pdisp.py", line 1125, in MouseActions
self.OnMouseMoving(event)
pdisp.py", line 2011, in OnMouseMoving
TypeError
TypeError
TypeError
What is wrong?
The vectormap contains floating point coordinates, and reading the report of Martin Landa (Perugia, 21-22 Feb 2008)
wxPython-based GUI for GRASS GIS
"the general display architecture needs to bee improved to support floating-point coordinates"
Is here the problem
thanks for help
Joop Goedbloed
Date: Thu, 20 Nov 2008 21:20:22 +0100
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] error running digitzing tool wxpython
Check if you compiled the source code -with-python
"-with-python" is not enough to get the new wxPython GUI installed.
That is only required for the new vdigit.
Running the digitize tool I’ve the following error masseges:
if len(self.vdigitMove[‘id’]) > 0:
TypeError
File “/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/ma
pdisp.py”, line 1125, in MouseActions
pdisp.py”, line 2011, in OnMouseMoving
TypeError
TypeError
TypeError
What is wrong?
“the general display architecture needs to bee improved to support
floating-point coordinates”
Is here the problem
thanks for help
Joop Goedbloed
Jhon Ortiz Trujillo
Geologist - EOS-DTH - ICP
Bogotá - Colombia
No te aburras más, engánchate a los Juegos de Messenger
Hi.
2008/11/20 Joop Goedbloed <jlgoedbloed@hetnet.nl>:
Please report exactly what steps you did to reach this error.
TypeError
What is wrong?
Is here the problem
no, it's unrelated (at least for grass6). Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
2008/11/21 Joop Goedbloed <jlgoedbloed@hetnet.nl>:
Grass6.4 is configured with --with-cxx --with-python --with-wxwidgets
The wx digitizing tool runs fine zoomin and zoom out is running fine.
as soom when I edit some vertex like movevertex splitvertex etc. the tool
seems to hang and I become this errors.
I will check it ASAP, I am out of the office right now. So, you open
vector map for editing, choose vertex to be moved by left mouse
button, error appears... Is it right?
Martin
Hello Users-Group
Doing some research the error below has something to do with the settings.
I've set the snapping on 10 and save the settings.
The tool runs more better but slower then v.digit (tcltk)
the tool differs also from the v.digit tool
Here is a link to three images.
img1 <ftp://80.61.251.86/grass64/J09v_digit.jpg&gt;
img2 <ftp://80.61.251.86/grass64/J09map_display.jpg&gt;
img3 <ftp://80.61.251.86/grass64/J09wxpython_tool.jpg&gt;
A map with paved areas of roads:
J09v_digit.jpg (v.digit map) every boundary is green with centriods in each paved area.
J09map_display.jpg is th same map in the display this is correct.
J09wxpyton_tool.jpg (same map wit the wxpython tool with the setting areas cheched 'on'
This map is not correct.
here is the link
maps <ftp://80.61.251.86/grass64/&gt;
What is wrong
Joop Goedbloed
Martin Landa schreef:
Martin
