[GRASS-user] Error running g.mapset
Greetings
I’m running WinGRASS and I’m obtaining a weird error when I run g.mapset:
ERROR: Unable to read GIS_LOCK environment variable
How can I fix this in Win GRASS?
Thanks
Best regards
Kat
On Thu, Oct 14, 2010 at 3:07 PM, katrin eggert
<katrineggert1980@gmail.com> wrote:
Greetings
I'm running WinGRASS and I'm obtaining a weird error when I run g.mapset:
I have seen
Author: glynn
Date: 2010-10-14 02:51:09 -0700 (Thu, 14 Oct 2010)
New Revision: 43906
Modified:
  grass/trunk/general/g.mapset/main.c
Log:
Don't set option defaults from current state (results in incorrect
documentation).
but I don't know if this is related nor if this should be backported.
I have seen
Author: glynn
New Revision: 43906
Modified:
Log:
documentation).
It's not related.
The underlying bug (init.bat doesn't set GIS_LOCK) is still present in
6.5-svn. It isn't applicable to 7.0, where init.sh/init.bat have been
replaced by a Python script (which does set GIS_LOCK).
On Sat, Oct 16, 2010 at 8:26 AM, Glynn Clements
I have found this GPL program to the the PID which is needed
to set GIS_LOCK:
http://www.scheibli.com/projects/getpids/
Would that be of interest? Or is %RANDOM% together with something
else sufficient?
to set GIS_LOCK:
else sufficient?
AFAICT, GIS_LOCK needs to be set to an integer, but the actual value
is irrelevant on Windows.
g.mapset reads GIS_LOCK, passes it to $GISBASE/etc/lock, and checks
that etc/lock returns a zero exit code.
On Windows, etc/lock does nothing:
  int main(int argc, char *argv)
      if (argc != 3 || sscanf(argv[2], "%d", &lockpid) != 1)
    G_fatal_error("usage: %s file pid", argv[0]);
  #ifdef __MINGW32__
      G_warning("Concurrent mapset locking is not supported on Windows");
      exit(0);
  #else
If GIS_LOCK isn't set, g.mapset will complain. If it doesn't parse
with "%d", etc/lock will complain. Other than that, it shouldn't
matter.
On Sat, Oct 16, 2010 at 3:32 PM, Glynn Clements
to set GIS_LOCK:
else sufficient?
At this point, would adding this line suffice?
set GIS_LOCK=1
   int main\(int argc, char \*argv\[\]\)
       if \(argc \!= 3 || sscanf\(argv\[2\], &quot;%d&quot;, &amp;lockpid\) \!= 1\)
           G\_fatal\_error\(&quot;usage: %s file pid&quot;, argv\[0\]\);
   \#ifdef \_\_MINGW32\_\_
       G\_warning\(&quot;Concurrent mapset locking is not supported on Windows&quot;\);
       exit\(0\);
   \#else
matter.
If there are no objections, I'll submit above.
set GIS_LOCK=1
AFAICT, yes.
On Sun, Oct 17, 2010 at 6:48 PM, Glynn Clements
set GIS_LOCK=1
AFAICT, yes.
Done so in 6.4 and 6.5 (I don't know about 7).
@Katrin: you may just add this line in your local installation.
