[GRASS-user] Error running r.reclass in python script with stdin
I try to run a python script including the r.reclass command with stdin.
I am running GRASS 6.5.svn50782M (2012) on a Mac OSX. The part of the script is:
  grass.run_command("r.reclass",
          input = "Treene_tmp_mask1",
          rules = "-",
          stdin = '1 thru 999 = 1 1',
          output = "Treene_mask_2")
and the error:
  File "/Users/Johannes Radinger/Desktop/SDM_V2R.py", line
92, in <module>
    sys.exit(main())
68, in main
  File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/pytho
n/grass/script/core.py", line 189, in run_command
    ps = start_command(*args, **kwargs)
n/grass/script/core.py", line 177, in start_command
    return Popen(args, **popts)
n/grass/script/core.py", line 56, in __init__
    startupinfo, creationflags)
  File "/Library/Frameworks/Python.framework/Versions/2.6/li
b/python2.6/subprocess.py", line 616, in __init__
    errread, errwrite) = self._get_handles(stdin, stdout,
stderr)
b/python2.6/subprocess.py", line 973, in _get_handles
    p2cread = stdin.fileno()
AttributeError: 'str' object has no attribute 'fileno'
What I am doing wrong or is there a bug in the code?
best regards,
Johannes
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://mobile.1und1.de/?ac=OM.PW.PW003K20328T7073a
On 06/03/12 11:42, Johannes Radinger wrote:
          rules = "-",
and the error:
92, in<module>
     sys.exit(main())
68, in main
stderr)
You have to use grass.write_command to be able to use stdin.
Moritz
