[GRASS-user] Error starting GRASS71 trunk: module catalog missing?
I tried to start the most recent (SVN up) self-compiled version of GRASS71 on a Ubuntu-machine. GRASS starts and I can selected a location/mapset from the GUI but after the selection I get following error and the GUI does not start:
Launching GUI in the background, please wait…
GRASS 7.1.svn (nc_spm_08):~ > NumPy not found.
This module requires the NumPy module, which could not be
imported. It probably is not installed (it’s not part of the
standard Python distribution). See the Numeric Python site
(http://numpy.scipy.org) for information on downloading source or
binaries.
File “/usr/local/grass-7.1.svn/gui/wxpython/wxgui.py”, line 140, in
sys.exit(main())
File “/usr/local/grass-7.1.svn/gui/wxpython/wxgui.py”, line 132, in main
app = GMApp(workspaceFile)
File “/usr/local/grass-7.1.svn/gui/wxpython/wxgui.py”, line 46, in init
wx.App.init(self, False)
File “/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_core.py”, line 8628, in init
self._BootstrapApp()
File “/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_core.py”, line 8196, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/usr/local/grass-7.1.svn/gui/wxpython/wxgui.py”, line 79, in OnInit
from lmgr.frame import GMFrame
File “/usr/local/grass-7.1.svn/gui/wxpython/lmgr/frame.py”, line 73, in
from datacatalog.catalog import DataCatalog
ImportError: No module named catalog
I am not sure why I get the errors concerning numpy as this is installed and can be loaded:
radinger@grassgis:~$ python
Python 2.7.3 (default, Jun 22 2015, 19:43:34)
[GCC 4.6.3] on linux2
Type “help”, “copyright”, “credits” or “license” for more information.
import numpy
However, I am more worried about the error (or the failure of the GUI which does not start) related to the messages on the wx-module “No module named catalog”. There were no errors during configuration and compilation of the source code of GRASS.
I have also compiled and installed GRASS 7.0.2svn, here the GUI starts without any problems (however, I get the messages concerning numpy, but it seems they don’t have any effect on running GRASS)
So what is the reason for GRASS71 to fail here? I have installed wxpython 3.0.1:
import wx
wx.VERSION_STRING
‘3.0.1.0’
wx.version()
‘3.0.1.0 gtk2 (classic)’
Any suggestions?
Johannes
2015-11-24 14:39 GMT+01:00 Johannes Radinger <johannesradinger@gmail.com>:
several times discussed, please delete installation directory
(/usr/local/grass-7.1.svn) and compile from scratch (distclean,
configure, make, make install). Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Thanks Martin,
It seems that deleting the installation directory helped!
/Johannes
On Tue, Nov 24, 2015 at 2:58 PM, Martin Landa <landa.martin@gmail.com> wrote:
Martin Landa
