Hello all
Each time I try to display any vector map, I get the error that follows:
d.vect map=roads color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape type=point,line,boundary,centroid icon=basic/circle size=5 layer=1 lsize=8 xref=left yref=center llayer=1
Sorry, <layer> is not a valid parameter
ERROR: value <roads> out of range for parameter <map>
Legal interval: point,line,boundary,centroid,area,face
ERROR: Required parameter <output> has not been initialised:
Same maps in other computer don't give error. Using 6.3.cvs.
Can anyone tell me what is wrong?
Regards
Carlos
On Thu, Mar 08, 2007 at 08:39:54PM +0100, Carlos D?vila wrote:
Hello all
Carlos,
this sort of "parameter shift" happens when the GRASS parser
was changed *and* no complete recompile was done.
You can solve it like this:
make distclean
./configure ....
make
make install
Only a complete recompile will solve this problem. Usually the
parser (lib/gis/parser.c) isn't touched too often, that's why
an update from CVS plus "make" normally works.
Hello all
Carlos,
make distclean
./configure ....
make
make install
Right, it worked.
Thank you
