[GRASS-user] Error trying to export a database table
Hi all:
I’m using GRASS on a Mac:
GRASS version: 7.8.6dev
Code revision: 0d636df8f
Build date: 2021-09-09
Build platform: x86_64-apple-darwin20.6.0
GDAL: 3.1.4
PROJ: 7.1.1
GEOS: 3.8.1
SQLite: 3.35.4
Python: 3.8.8
wxPython: 4.1.1
Platform: macOS-10.16-x86_64-i386-64bit
I get an error trying to export a database table using…
db.out.ogr --overwrite input=CEATI_dams_not_RR_gauge_rfc_fcst@teaiii output=/Users/teaiii/CEATI_dams_not_RR_gauge_rfc_fcst format=CSV table=CEATI_dams_not_RR_gauge_rfc_fcst
ERROR:
GRASS 7.8.6dev (global-dataset):~ >
<fcst@teaiii output=/Users/teaiii/CEATI_dams_not_RR_gauge_rfc_fcst format=CSV table=CEATI_dams_not_RR_gauge_rfc_fcst
WARNING: The combination of types is not supported by all formats.
ERROR 10: Pointer ‘hSRS’ is NULL in ‘OSRImportFromWkt’.
ERROR: Unable to create OGR spatial reference
ERROR: Module <v.out.ogr> failed
This happens using with the GRASS GUI or from the command line.
Any suggestions?
Tom
Hello Tom
It is the same error as reported here: https://lists.osgeo.org/pipermail/grass-dev/2021-November/095454.html
I have encountered it myself but it’s not clear where it comes from. It happens in only one location (an old latlong one) and I can’t reproduce with other locations. I use Fedora Linux.
Sorry for not being of more help.
Vero
El jue, 2 dic 2021 a las 19:40, Thomas Adams (<tea3rd@gmail.com>) escribió:
Hi all:
GDAL: 3.1.4
PROJ: 7.1.1
GEOS: 3.8.1
SQLite: 3.35.4
Python: 3.8.8
wxPython: 4.1.1
ERROR:
Any suggestions?
Tom
grass-user mailing list
grass-user@lists.osgeo.org
Hi Veronica!
Thank you for your response and the information. At least I know that I am not doing anything wrong …
Best,
Tom
Hi Tom,
Note that if all you want is to create a CSV file from the attribute table, v.db.select can do the job for you. In GRASS 8 it actually has a format parameter that lets you choose CSV explicitly, but even without that you can get a satisfying result.
Moritz
Hi Moritz!
Thank you so much! That’s a great idea… oddly enough, after you mention this, I remember seeing this for v.db.select.
Thanks again!
Best,
Tom
On Fri, Dec 3, 2021 at 9:18 AM Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi Tom,
Moritz
Le 3 décembre 2021 13:48:58 GMT+01:00, Thomas Adams <tea3rd@gmail.com> a écrit :
Hi Veronica!
Best,
Tom
On Fri, Dec 3, 2021 at 6:14 AM Veronica Andreo <veroandreo@gmail.com> wrote:
Hello Tom
Vero
Hi all:
GDAL: 3.1.4
PROJ: 7.1.1
GEOS: 3.8.1
SQLite: 3.35.4
Python: 3.8.8
wxPython: 4.1.1
ERROR:
Any suggestions?
Tom
