[GRASS-user] Error trying to mosaic two images
femgo wrote:
Hello, I´m new GRASS´s user, so probably this is question have already
been asked.
no, I don't think it has, so thanks for the report.
I have two geotiff images that I want to mosaic,
(did you try r.patch? perhaps i.image.mosaic is overkill)
but GRASS shows this error:
Mosaicing two images...
syntax error, unexpected '@', expecting '='
Parse error
C:/Arquivos de programas/GRASS6.4RC1/scripts/i.image.mosaic: line 98:
the r.mapcalc call apparently does not like the @mapset in the input
names. I suspect a little \"quoting\" of the variables within the mapcalc
statement will help.
(btw, in general the imagery libraries do not like @mapset very much,
but this one is just a little quoting bug I think)
It says the problem is the @, which was put automatically into the
images´s name to indicate where it is.
How should I proceed?
@PERMANENT and the current mapset are always in the mapset search path
(unless you do something silly) so you can safely remove the @mapset
part before you run the module.
Thanks in advance and sorry for the poor english. --
your english is just fine.
Hamish
> Parse error
Quoting will make r.mapcalc accept a qualified name on the LHS of the
"="; however, the name must still refer to the current mapset.
But r.mapcalc is the least of the problems. i.image.mosaic
fundamentally expects the map names to be unqualified.
Thanks for the help guys.
I used r.patch, it´s the better solution here.
2011/12/5 Glynn Clements <glynn@gclements.plus.com>
Hamish wrote:
syntax error, unexpected ‘@’, expecting ‘=’
Parse error
names. I suspect a little "quoting" of the variables within the mapcalc
“=”; however, the name must still refer to the current mapset.
Felipe Moreira Gonçalves
