Hello!
Has anyone experience with using r.sim.water under Windows? I'm planning to
use it for the simulation of flash flood events.
I tried it with a DEM (1m resolution) with the following region setting:
g.region -p
rojection: 99 (Transverse Mercator)
zone: 0
datum: potsdam
ellipsoid: bessel
north: 5377000.5
south: 5375999.5
west: 3502999.5
east: 3504000.5
nsres: 1
ewres: 1
rows: 1001
cols: 1001
cells: 1002001
I calculated the first order partial derivative dx and dy with
r.slope.aspect
(Do I have to use degrees in the settings?)
Leaving everything else unchanged for a testrun, I get the following message
and r.sim.water crashes:
"r.sim.water.exe hat ein Problem festgestellt und muss beendet werden."
("r.sim.water.exe has detected a problem and has to be closed")
Can anyone tell me what's going wrong? Would it be better to use GRASS under
Linux for this purpose?
Thanks for your help,
Bernd
View this message in context: http://n2.nabble.com/error-using-r.sim.water-tp2981358p2981358.html
