[GRASS-user] Error when creating a location using v.in.ogr from a geojson file.
I am trying to create a location by importing the following geojson file:
“type”: “FeatureCollection”,
“crs”: {
“type”: “name”,
“properties”: { “name”: “urn:ogc:def:crs:EPSG::3358” }
“features”: [
“type”: “Feature”,
“properties”: { “cat”: 1 },
“geometry”: {
“type”: “Point”,
“coordinates”: [ 638042.52336448605638, 223793.925233644869877, 0.0 ]
This is what I get:
GRASS 7.0.3svn (MyLoc):~/ > v.in.ogr -i location=‘foo_location’ input=~/reservoir_point.json --verbose
WARNING: All available OGR layers will be imported into vector map
Location <foo_location> created
ERROR: Syntax error in cell header
As you can see, the location gets created but then there is an ERROR. Can anyone explain what is the problem in this case. Using a geojson file with a different geometry type works just fine:
“crs”: {
“type”: “name”,
“features”: [
“type”: “Feature”,
“geometry”: {
“type”: “LineString”,
“coordinates”: [
[ 637714.48598130850587, 222910.747663551388541, 0.0 ],
[ 638484.112149532767944, 223453.271028037386714, 0.0 ],
[ 639026.635514018707909, 224197.663551401870791, 0.0 ],
[ 639152.803738317801617, 224803.271028037386714, 0.0 ]
I am using revision 67592.
all the best,
Panos
