Hello everyone, I am a graduate student in the Masters in GIS program at
Penn State World Campus. For my thesis, I will be using GRASS and
R-spatial to look at whether a correlation exists between persons with
asthma and industrial emissions in New Mexico, USA. I will also be
using MapServer and OpenLayers to make the data (and methods used)
available on the Web. During the project, I will only be using Open
Source. Additionally, as part of graduation requirements, I will be
presenting my work at a conference in 2009 (undecided on which
conference).
I am in the process of learning GRASS and ran into an error message as I
was working through the text in Neteler's book "Open Source GIS:A Grass
Approach" (3rd edition), page 37, Section 3.2: Starting GRASS with a new
project.
Side note: installed Grass 6.2.2 using apt-get in Ubuntu 7.10.
After starting a new project using the "start new location with a
georeferenced file" option, I get an error when I click "Define
Location". I am using the North Carolina sample data and using the
gdc.prj for the georeferenced file. The error is as follows:
/usr/bin/x-terminal-emulator: to set an icon, please use -name <profile>
and set a profile icon
while executing
"exec -- $env(GISBASE)/etc/grass-xterm-wrapper -T g.proj -n g.proj -e
$env(GISBASE)/etc/grass-run.sh g.proj -c georef=$filepath location=
$fileLocation"
invoked from within
".fileloc.def invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke]"
(procedure "tk::ButtonUp" line 22)
invoked from within
"tk::ButtonUp .fileloc.def"
(command bound to event)
I am new to Linux as well, so any insight on this error is much
appreciated.
Thanks for the help and look forward to being a part of the GRASS
community.
Maybe it works, I'm not sure - it might just concentrate on the layer
name not the extension - but I thought it wanted the .shp file for that,
not the .prj file that comes with it? (from within GRASS, you can feed
it that definition with 'g.proj wkt=gdc.prj')
<profile>
appreciated.
We saw this before with Ubuntu; a quick mailing list search finds:
I believe the problem is that the version of x-terminal-emulator ->
/usr/bin/gnome-terminal.wrapper on your system is broken. Probably fixed
with Hardy Heron?
Anyway there is a quick fix: before starting GRASS set the default
terminal to something other than gnome-terminal:
export GRASS_TERMINAL=xterm
grass62
or another like rxvt. ("aptitude install xterm" if you need it; put the
setting in ~/.bashrc if you want to make it permanent)
community.
Welcome, you project sounds both interesting and worthwhile.
Indeed, I also get that error.
There is a .shp file too, please use that file.
@developers: I think that we need a test in the location definition part of
the code if the user provided a .prj file or something else to make use
of the right g.proj parameters.
It is function proc epsgOpt::runproj in lib/init/epsg_option.tcl
> <profile>
This is an Ubuntu bug. In GRASS 6.3 this part was modified to
also work with Ubuntu. Please consider to update (hopefully
an Ubuntu package comes out soon).
Hamish: that's not fair! Is searched the mailing list for the error
before posting but didn't get any results.
I also considered installing 6.3 from source. Decided to post first. I
will upgrade to Ubuntu Hardy and try GRASS from the repo to see if it
works (out of curiosity) then report back. Then I will install 6.3 from
source.
I tried the *.shp file before posting. Same error.
Just tried exporting the terminal xterm (GRASS_TERMINAL=xterm). Same
error.
Well, time to backup and install Hardy.
Thanks for the help.
Andrew Parker
> > <profile>
Occasionally the htDig search tool gives no hits for any search term,
even something like "GIS". Me, I prefer to search using the Gmane
archive; others like the Nabble archive. shrug.
error.
(sorry about giving you the wrong variable name for that, my bad)
That's easy to answer: htdig isn't installed right now.
I really (!) need help here:
- set up awstats on grass.osgeo.org
- set up htdig on grass.osgeo.org
- bother to set up htdig on lists.osgeo.org (see osgeo trac ticket,
Wolf should have acces)
