[GRASS-user] error when digitizing polygons in a grass database with qgis
Dear all,
Has anyone experience with digitizing polygons in a grass database with QGIS?
I try to digitize vector polygons in a grass database in qgis as dicribed in the QGIS help.
https://docs.qgis.org/3.16/en/docs/user_manual/grass_integration/grass_integration.html#creating-a-new-grass-vector-layer
It works well with points and lines. But with polygons I am not able to capture data. I add a closed boundary and add a centroid. When saving the data I get a message that the geometry type is not compatible. When I try to build the topology with v.build I get a warning "coor file of vector map <name of map>is larger than it should be”.
Has anyone an idea? Thanks a lot!
Kind regards,
Klaus
