I am trying to import a *.gml file which I received from a governmental agency. However when trying v.import I get an error message (see below). I can successfully import the file in QGIS (and display the attribute table). Other gml files from the same region and from the same provider work also.
I can imagine it might be related to some attribute names?! Is the attribute name ‘order’ not a valid column name as ORDER is also an sqlite command? Anybody any ideas what’s wrong with the file or the import?
cheers,
Johannes
Importing </…/FLUSSORDNUNGSZAHL_NGP2015.gml> …
Check if OGR layer contains polygons…
Creating attribute table for layer …
Default driver / database set to:
driver: sqlite
database: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
Column name <inspireId|Identifier|localId> renamed to <inspireId_Identifier_localId>
Column name <inspireId|Identifier|namespace> renamed to <inspireId_Identifier_namespace>
DBMI-SQLite driver error:
Error in sqlite3_prepare():
near “order”: syntax error
ERROR: Unable to create table: 'create table Watercourse (cat integer, gml_id text, language varchar ( 3 ), nativeness text, sourceOfName text, pronunciation text, text varchar ( 90 ), script varchar ( 4 ), transliterationScheme text, grammaticalGender text, grammaticalNumber text, classificationScheme varchar ( 8 ), localId integer, namespace varchar ( 83 ), beginLifespanVersion varchar ( 25 ), inspireId_Identifier_localId integer, inspireId_Identifier_namespace varchar ( 83 ), versionId varchar ( 5 ), origin text, persistence text, tidal text, drainsBasin text, delineationKnown integer, length double precision, length_uom varchar ( 1 ), level text, order varchar ( 36 )
^-- order is a reserved SQL word, please rename the column before importing.
