I’ve been a reader in the Grass-users list so far but I wanted to follow up with this:
I was trying to get a py script running under Grass 6.4 and 7.0
OS: WIndows 7 64 bit
Here are the results of my experiments, I will try to provide as much detail as I can:
I am using http://svn.osgeo.org/grass/grass-addons/raster/r.ipso/ for my tests:
GRASS64
I have GRASS 64 installed in C:\GRASS-64
I put the the r.ipso.py in C:\GRASS-64\scripts
I launch the GRASS 6.4.0 with MSYS
when I directly try to launch the module, I get this:
GRASS 6.4> r.ipso.py
File “c:/GRASS-64/scripts/r.ipso.py”, line 53, in
import matplotlib.pyplot as plt
File “C:\GRASS-64\Python25\lib\site-packages\matplotlib\pyplot.py”, line 78, in
new_figure_manager, draw_if_interactive, show = pylab_setup()
File “C:\GRASS-64\Python25\lib\site-packages\matplotlib\backends_init_.py”, line 25, in pylab_setup
globals(),locals(),[backend_name])
File “C:\GRASS-64\Python25\lib\site-packages\matplotlib\backends\backend_tkagg.py”, line 7, in
import Tkinter as Tk, FileDialog
ImportError: No module named Tkinter
I could workaround this problem by using the Python 26 installed separately in C:\Python26 (which has numpy, matplotlib, wx-2.8-msw-unicode (wxpython) etc)
apparently python26 interpreter can run the matplotlib better(?).
so I did:
GRASS 6.4> export PATH=“/C/GRASS-64/lib:/C/GRASS-64/bin:/C/GRASS-64/scripts:/C/GRASS-64/tcl-tk/bin:/C/GRASS-64/sqlite/bin:/C/GRASS-64/gpsbabel:/C/GRASS-64/extralib:/bin:/C/Python26”
GRASS 6.4> export PYTHONHOME=“/C/Python26”
note that I removed the C/Grass-64/extrabin to prevent the python.exe there to interfere with my python.exe (the one in C:\Python26) to execute - If I don’t remove C/Grass-64/extrabin from the PATH, here is the result:
c:/Python26\lib\site.py:150: Warning: ‘with’ will become a reserved keyword in Python 2.6
‘import site’ failed; use -v for traceback
File “c:/GRASS-70-SVN/scripts/r.ipso.py”, line 52, in
import os
File “c:/Python26\lib\os.py”, line 758
bs = b""
SyntaxError: invalid syntax
so anyway, I change the path as I mentioned above and the result is:
ERROR: Required parameter not set:
(Name of raster map).
(output graph).
Description:
Keywords:
raster
Usage:
r.ipso.py [-ab] map=name image=image [–verbose] [–quiet]
Flags:
-a generate ipsometric curve
-b generate ipsographic curve
–v Verbose module output
–q Quiet module output
Parameters:
map Name of raster map
image output graph
GRASS 6.4>
so it works, I tried it with an input map and everything. It creates the plot image and everything but the GUI does not launch (in linux it does - everything works better there
). I want the GUI so that when I create my own script I can check how the GUI looks etc.
I tried the same thing GRASS 7 too since it is all Python (which I love ! )
I get a different error when I go r.ipso.py just after launching GRASS 7.0.SVN with MSYS (Grass7.0 is installed in C:\GRASS-70-SVN - I mention this to let you know that I don’t go with the default C:\Program Files (X86)\GRASS… which has spaces in it and it creates all kinds of problems - I see that it is been fixed, but I still feel this is safer)
GRASS 7.0.svn> r.ipso.py
File “c:/GRASS-70-SVN/scripts/r.ipso.py”, line 53, in
ImportError: No module named matplotlib.pyplot
the reason (probably), C:\GRASS-70-SVN\Python25\Lib\site-packages does not come with matplotlib - anyway I trick it again to look for libraries under my Python26 by exporting:
export PATH=“/C/GRASS-70-SVN/lib:/C/GRASS-70-SVN/bin:/C/GRASS-70-SVN/scripts:/C/GRASS-70-SVN/tcl-tk/bin:/C/GRASS-70-SVN/sqlite/bin:/c/GRASS-70-SVN/gpsbabel:/c/GRASS-70-SVN/extralib:/bin:/c/Python26”
again note that I don’t have the extrabin folder in the PATH
ERROR: wxGUI requires wxPython. No module named wxversion
GRASS 7.0.svn>
This is where I am at right now - it seems that it is going to work out if I figure out this last “ERROR: wxGUI requires wxPython. No module named wxversion” problem in Grass-70.
Any ideas, suggestions ?
I just want to be able to launch the GUI when I have a .py of my own under /scripts in grass6.4 or 7.0
thanks
Onur
M.Onur Kurum
Graduate Research Assistant
Dept. of Civil, Construction, and Environmental Engineering
North Carolina State University
Campus Box 7908
2501 Stinson Drive, 428 Mann Hall
Raleigh, NC 27695-7908
Office: (919) 515-1340
Mobile: (919) 200-0665
Email: mokurum@ncsu.edu
Email: m.onur.kurum@gmail.com
Greetings to all
I want to know if anyone has ever tried to build Python Scripts on winGRASS 6.x???
Because I didn’t find any literature or document that this was a limition on Windows…
On Fri, Oct 1, 2010 at 6:40 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
Helena Herrera wrote:
I have developed a Script to import Landsat images that runs just fine in
Linux
But when I compile (Msys) with this expressioN:
make -C r.in.landsat
MODULE_TOPDIR=/C/OSGeo4W/usr/src/grass-6.4.svn_src_snapshot_2010_09_04
and run in GRASS I get this error:
xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(enc).split(‘\n’,1)[1].replace(‘’,
‘<?xml version="1.0" encoding="utf-8"?>\n’, 1).encode(“utf-8”),
IndexError: list index out of range
1- Is my compilation expression correct?
2- What am I missing on this?
I’m not sure that Python scripts work in 6.x on Windows. I’m fairly
sure that the build system doesn’t handle Python scripts in 6.x on
Windows.
The main issue is that, on Windows, the build system installs a batch
file which executes the actual script, and the batch file only works
for shell scripts.
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
M.Onur Kurum
Campus Box 7908
