Greetings
I’m converting a reclasses raster (produced with r.reclass) to a vector (areas, not lines neither points) but I got this weird error:
ERROR: G_realloc: unable to allocate 24632000 bytes at areas.c:678
What does this mean?
Thanks
Franz
Greetings
Thanks
Franz
2010/11/9 Franz Schiller <franzschiller1975@gmail.com>:
I'm converting a reclasses raster (produced with r.reclass) to a vector
you are allocate 24Gb of memory, check out your computational region
g.region rast=raster_map
r.to.vect ...
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Hi Martin
I have done exacly that (the g.region stuff)
I believe my region is not so big.
Resolution:300
rows:5381
cols:4481
Any more tips on this?
Franz
On Tue, Nov 9, 2010 at 11:01 AM, Martin Landa <landa.martin@gmail.com> wrote:
What does this mean?you are allocate 24Gb of memory, check out your computational region
r.to.vect …Martin
