[GRASS-user] Error while creating vectorial file in WinGRASS
I have installed WinGRASS-6.4.SVN-r42868-1-Setup.exe in my WinXP machine and, when I select Vector/Develop Vector Map/Create new vector map, I place output name and check Create Attibute table I get an error windows stating:
  • Error in command execution db.execute
    Execution failed: ‘db.execute --q’
    Details:
    Error: Unable to start driver <(null)>
And the following is printed in Command Output:
File “C:/GRASS6/etc/wxpython/wxgui.py”, line 546, in
OnNewVector
cmdDef=([‘v.edit’, ‘tool=create’], “map”))
File “C:\GRASS6\etc\wxpython\gui_modules\gdialogs.py”,
line 192, in CreateNewVector
stdin=sql)
File “C:\GRASS6\etc\wxpython\gui_modules\gcmd.py”, line
369, in init
_("Error: ") + self.GetError()))
gui_modules.gcmd
CmdError
OnNewVector
stdin=sql)
369, in init
gui_modules.gcmd
CmdError
I believe this was not expected but, what might be wrong?
Thanks
Kim
You need to run db.connect to select a database backend to use
first. (There is no VAR file in the mapset yet)
Manage databases → connect
see the help page for details, I usually just cut and paste out of the examples. v.db.addtable can probably do this automatically.
Vector database connections → New Table
Most modules should create the connection if needed using the default
DB (dbf in grass 6.4) if it is needed, but because db.execute is “raw”
perhaps it shouldn’t and whatever in the GUI is calling that should
check that first.
Hamish
Kim Besson wrote:
> - Error in command execution db.execute
> Details:
> OnNewVector
> stdin=sql)
> 369, in init
> gui_modules.gcmd
> CmdError
> OnNewVector
> stdin=sql)
> 369, in init
> gui_modules.gcmd
> CmdError
> Thanks
> Kim
