[GRASS-user] error while displaying netCDF file
Hi list,
I’m trying to import a netCDF file I downloaded from here: http://oceandata.sci.gsfc.nasa.gov/MODISA/Mapped/8Day/4km/chl/
I’ve tried two different ways of importing:
r.in.gdal input=NETCDF:“A20030012003008.L3m_8D_CHL_chl_ocx_4km.nc”:chl_ocx output=test_chlor -o
and
gdal_translate -a_srs EPSG:4326 -a_ullr -180 90 180 -90 NETCDF:“A20030012003008.L3m_8D_CHL_chl_ocx_4km.nc”:chl_ocx test_chlor_b.tif
r.in.gdal input=test_chlor_b.tif output=test_chlor_b
In both cases I get this error when trying to display the map (both with d.mon - d.rast and in the GUI):
GRASS_INFO_ERROR(18597,1): Syntax error in cell header
GRASS_INFO_END(18597,1)
though, r.info test_chlor_b, seems fine
| Type of Map: raster Number of Categories: 0
| Data Type: FCELL
| Rows: 4320
| Columns: 8640
| Total Cells: 37324800
| Projection: Latitude-Longitude
| N: 90N S: 90S Res: 0:02:30
| E: 180E W: 180W Res: 0:02:30
| Range of data: min = 0.001 max = 99.96646
While transforming with gdal_translate and also when unsing r.in.gdal with the original netCDF file, I noted this:
Warning 1: dimension #1 (lon) is not a Longitude/X dimension.
Warning 1: dimension #0 (lat) is not a Latitude/Y dimension.
Input file size is 8640, 4320
0…10…20…30…40…50…60…70…80…90…100 - done.
I guess it is maybe related to the error? What does it mean? Can someone help me, please? QGIS displays it fine…
I’m using grass71 r67160, under fedora 22. GDAL 1.11.3
Thanks a lot! And sorry for my ignorance :confused:
Vero
ps: Here, the output of gdalinfo from original netCDF and the one converted with gdal_translate: http://pastebin.com/4c7Hk7cW
Sorry for the noise :slight_smile:
I solved it.
Just forgot “-l” in r.in.gdal and then set the bounds of the map properly with r.region.
Vero
2015-12-16 18:01 GMT-03:00 Veronica Andreo <veroandreo@gmail.com>:
Hi list,
and
| Data Type: FCELL
| Rows: 4320
| Columns: 8640
Vero
