On 26/10/11 10:57 AM, grass-user-request@lists.osgeo.org wrote:
Message: 1
Date: Tue, 25 Oct 2011 15:42:31 +0100
Subject: [GRASS-user] Error while importing shapefile
To: GRASS user list<grass-user@lists.osgeo.org>
Message-ID:<4EA6CAD7.5020203@deimos.com.pt>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedGreetings
I have tried to import this shapefile (that I can display in QGIS) but I
go this error
(Tue Oct 25 15:38:40
2011)
v.in.ogr dsn=/home/GPS_Project.shp layer=GPS_Project output=GPS_Project
Projection of input dataset and current location appear to match
Layer: GPS_Project
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected TIME, expecting
NAME processing 'time'
in statement:
create table GPS_Project (cat integer, ele
double precision, time varchar ( 80 ), magvar double
precision, geoidheigh double precision, name varchar ( 80 ),
cmt varchar ( 80 ), desc_ varchar ( 80 ), src varchar ( 80
), link1_href varchar ( 80 ), link1_text varchar ( 80 ),
link1_type varchar ( 80 ), link2_href varchar ( 80 ),
link2_text varchar ( 80 ), link2_type varchar ( 80 ), sym
varchar ( 80 ), type varchar ( 80 ), fix varchar ( 80 ), sat
integer, hdop double precision, vdop double precision, pdop
double precision, ageofdgpsd double precision, dgpsid
integer, label varchar ( 80 ))
Error in db_execute_immediate()
ERROR: Unable to create table: 'create table GPS_Project (cat integer,
ele double precision, time varchar ( 80 ), magvar double precision,
geoidheigh double precision, name varchar ( 80 ), cmt varchar ( 80 ),
desc_ varchar ( 80 ), src varchar ( 80 ), link1_href varchar ( 80 ),
link1_text varchar ( 80 ), link1_type varchar ( 80 ), link2_href varchar
( 80 ), link2_text varchar ( 80 ), link2_type varchar ( 80 ), sym
varchar ( 80 ), type varchar ( 80 ), fix varchar ( 80 ), sat integer,
hdop double precision, vdop double precision, pdop double precision,
ageofdgpsd double precision, dgpsid integer, label varchar ( 80 ))'
(Tue Oct 25 15:38:41 2011) Command finished (0 sec)Any suggestion on how to solve this?
Thanks
Best regards,
Antonio
Antonio - I think "time" is not allowed as a field name in some databases?
If that's the problem, then you need to specify the field names for v.in.ogr import, using the cnames flag - and instead of naming the field "time", call it something else (my_time would do, I suppose).
With a big table, this is a pain in the neck, but I think it's your only choice.
Richard C
