Greetings
I'm trying to remove a file named new_clump@Area and I get this error:
[new_clump@Area] is a base map for [myscript.tmpV@Area]. Remove forced.
misc: couldn't be removed
I'm already using -f flag from g.remove function.
myscript.tmpV was a file that I generated from this new_clump. But, now I don't have that file in Area MAPSET ( I already checked in the Area folder) so I wasn't suppose to get this error.
How can I remove this raster without getting this nonsense error
Thanks
Best regards,
Antonio R.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5952 (20110314) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
"is a base map for" is just a warning; it doesn't prevent removal so
long as the -f flag is given.
This indicates that there was some problem with removing the cell_misc
directory.
Ok it has removed but when I try to write over that file I get errors like Permission DENIED.
WHat can I do to fix this?
directory.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5955 (20110315) __________
http://www.eset.com
Ensure that all files and directories within the mapset directory are
owned by you, and have the necessary permissions (read and write for
files, read, write and execute for directories).
Hello Glynn
I'm running in WinGRASS in WinXP and I have total access to my folders (as far as I can see) but I get Permission denied for a specific folder in C:\grassdata\Area1\Country\cell_misc and ACCESS DENIED.
I have built a very long and "complex" Script with a lot of files production, deleting, opening external configuration files bla bla and now I'm getting this sort of errors when I try to overwrite over existing data or when I try to delete some files.
What might be happening?
Thanks
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5956 (20110315) __________
http://www.eset.com
Hi again
Ok the main problem is that I'm using r.statistics with base=new_clump10 and cover= myscript.tmpV1
If I try to remove new_clump I get:
g.remove -f rast=new_clump10@area
[new_clump10@area@area] is a base map for [myscript.tmpV1@area]. Remove forced.
Removing raster <LULC_new_clump10@National>
So it wasn't removed. My question is:
1- Why it's repeating the Mapset information (new_clump10@area@area) That is odd right? Maybe that is what is messing with the system
Thanks
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5957 (20110316) __________
http://www.eset.com
Just one small note:
If I try to remove tmpV I get this
Removing information about reclassed map from [new_clump10@area] failed
Removing raster <myscript.tmpV1@National>
And it's removed but then If I try to remove the new_clump10 I get:
[new_clump11@area@area] is a base map for [myscript.tmpV1@area]. Remove forced.
Removing raster <new_clump11@area>
Hi again
Thanks
Antonio
http://www.eset.com
forced.
It appears to be a bug with something not correctly handling qualified
names.
Rast_put_reclass() is a likely candidate:
sprintf(buf2, "%s@%s\n", name, G_mapset());
This should be e.g.:
xname = G_fully_qualified_name(name, G_mapset());
which will only add the mapset if the name is unqualified.
Also, the "misc: couldn't be removed" is probably because
G_is_reclassed_to() doesn't close the cell_misc/<name>/reclassed_to
file. On Windows, you cannot delete a file if it's open.
Can someone check r45681 and back-port?
2011/3/16 Glynn Clements <glynn@gclements.plus.com>:
names.
xname = G\_fully\_qualified\_name\(name, G\_mapset\(\)\);
I didn't test but backported (unsubmitted, see email in grass-dev).
This will hopefully solve the long term mystery of reclass files
sometimes not being deletable.
